Old 08-31-2009, 06:55 PM   #111 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
That's what I thought, but in Ty's stats it says OAL (comp. length) so I got a little confused. I suppose the lengths being different will force me to decide which axles I'll use before making the mounts since that are indeed different...
Mounts are gonna be trouble. I'll post pictures soon!
Old 08-31-2009, 08:28 PM   #112 (permalink)
Dartmouth 2010
SVOboy's Avatar
Picture time once again
In the last image you can start to anticipate the issues with making custom mounts for this damn thing.
ID:	4140   Click image for larger version
ID:	4141   Click image for larger version
ID:	4142   Click image for larger version
ID:	4143   Click image for larger version
ID:	4145   Click image for larger version
ID:	4146   Click image for larger version
ID:	4147   Click image for larger version
ID:	4148   Click image for larger version
ID:	4150   Click image for larger version
ID:	4151   Click image for larger version
ID:	4152   Click image for larger version
Old 08-31-2009, 08:31 PM   #113 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
So they do... Now that's gonna bug the hell out of me. I'm calling someone in the 'morrow to find out about that, probably R'axles.
I'll reference that by calling a Honda dealer and cross referencing the data, to make sure that they're not confused like we currently are.
Of course, you should also measure the axles while they're compressed, for posterity.
Old 08-31-2009, 08:34 PM   #114 (permalink)
Hi Ben,
You are a MUCH braver man that I...
Old 08-31-2009, 08:34 PM   #115 (permalink)
Dartmouth 2010
SVOboy's Avatar
Measured, they will be.
Something like this is what I'll need for the rear mount:
For a while I thought the K kit might work for my E series motor, but looking at the driver's side mount has convinced me this is not true.
Old 08-31-2009, 08:35 PM   #116 (permalink)
Dartmouth 2010
SVOboy's Avatar
Hi Ben,
Maybe you're confusing bravery with stupidity
Old 08-31-2009, 08:40 PM   #117 (permalink)
Maybe you're confusing anxiety with fear?
Re: the mounts -
They're really not all that difficult to make, but it all depends on how stiff/soft you want your mounts to be. If you're hardcore, and you're OK with vibration, you don't even need rubber inserts. If you're not cool with vibrations, you'll want some give in your mounts, so you should use one side of each mount that has rubber in it. There are also "in between" settings, which can be achieved with pourable urethanes.
There isn't going to be a "simple" kit that will put that engine in that chassis. It's just not going to happen. Get yourself plenty of 3mm steel and cutting/welding apparatus, as well as plenty of old cereal boxes and shoe boxes to cut your piece templates.
Old 08-31-2009, 08:42 PM   #118 (permalink)
Wait - we never really established... do you have a welder? Do you know how to weld?
Old 08-31-2009, 08:43 PM   #119 (permalink)
Dartmouth 2010
SVOboy's Avatar
Will 3mm be sufficient?
I'm currently running on broke so I can't afford a welder, so I'm hoping either ty will help or I'll try to rent one locally. Anyone know how much welder rental runs for?
Old 08-31-2009, 08:50 PM   #120 (permalink)
3mm is plate steel. I'm sure it will work out, since 90% of the structure of the car is made from >18g steel. LOL.
In all seriousness, yes, it will work. If you check the mounts, the plates they're made from, they're 3mm average. (3mm is 1/8")
What about the punk welder that someone posted on here awhile back? Cheap DIY thing, maybe that would be OK to use?
I guess it's kind of a non-issue for now, since you're going to first be interested in measuring and mocking up, right? For that, you need scissors, tape, rulers, etc... no welder required.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
