Old 09-01-2009, 11:43 PM   #161 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
But they're the wrong length!
Old 09-01-2009, 11:45 PM   #162 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
It will still let you get the height of the engine correct while the suspension is loaded, so the axles are straight. :P
I"m gonna check at the post office and see if they'll fit in any of the flat rate boxes. If they do, that'll rawk.
Old 09-01-2009, 11:51 PM   #163 (permalink)
Dartmouth 2010
SVOboy's Avatar
What to people recommend for height of the engine from the ground?
Old 09-02-2009, 12:04 AM   #164 (permalink)
Shouldn't be any lower than the lowest point of the cross member.
Old 09-02-2009, 11:31 AM   #165 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Have you tried to fit your hood on in the current configuration to see where it hits?
Old 09-02-2009, 12:40 PM   #166 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yep. It hits in the same place it hits for people with K swaps If it's not much hit after I lower it down a little I'm sure I may be able to get clearance by grinding off a little of the support beam
Old 09-02-2009, 01:24 PM   #167 (permalink)
Team ZX2
This is the nice thing about making your own motor mounts
Old 09-02-2009, 01:26 PM   #168 (permalink)
Dartmouth 2010
SVOboy's Avatar
It's the nice thing about having you do all the hard stuff for me
Old 09-02-2009, 01:57 PM   #169 (permalink)
Team ZX2
Difficulty is often a function of Expirience
My expirience tells me it will be difficult to make the time to help you. Having no expirience making Insight motor mounts for CRX's tells me "No Problem!" Ignorance is bliss...
Old 09-02-2009, 04:24 PM   #170 (permalink)
^^^ The Force is strong in this one...
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 12:59 PM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 07:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 02:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 11:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 06:14 PM
