Old 09-18-2009, 01:59 AM   #361 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Relax, dude... You'll get it figured out.
Here's what you do:
Remove the B1 wire from the ECU connector B.
Tape the terminal to the + (positive) post of the car's battery, and remove the normal battery + cable.
Be sure the battery is properly grounded to the chassis
Locate the bundle of wires under the hood that the B1 is bundled with.
Check each wire with a test light or multi-meter for voltage at the nearest terminal connector (don't pierce the wires, this brings about it's own problems down the road.)
If you don't get a 12VDC signal from any of the terminals, your problem is between the terminal connector and the ECU connector in the B1 wiring somewhere. Repeat this for anything that you'd like to find a short/open with, unless it's an open ground. If you apply power to an open ground, well, theorize.
Old 09-18-2009, 02:04 AM   #362 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Good idea, I'll try in the morning when the fumes from the gasoline aren't giving me a headache
Old 09-18-2009, 02:08 AM   #363 (permalink)
LOL - Gasoline headaches suck... I think I've gotten used to it, though... I don't get them anymore.
Have a good night's sleep, get back at it in the morning, after breakfast and coffee. Thank your neighbors for not complaining about noise/etc. sooner. They'll appreciate it.
Old 09-18-2009, 02:10 AM   #364 (permalink)
Dartmouth 2010
SVOboy's Avatar
Mayhaps, mayhaps. Right now I'm hitting the books trying to figure something out. The CEL light isn't working either, which is a separate issue, so we'll see how that goes
Old 09-18-2009, 02:13 AM   #365 (permalink)
So what does Mom have to say about all this "work" you're doing on your car?
I mean, I assume she knows what you're doing, why you're doing it, and how you ended up with her car in the mean time?
Old 09-18-2009, 02:27 AM   #366 (permalink)
Dartmouth 2010
SVOboy's Avatar
She wonders if it'll be done by sunday...Iono about that...
Old 09-18-2009, 02:32 AM   #367 (permalink)
Dude, Sunday is like 5 or 6 days away.
How did I come up with that? Read on:
Each "day" consists of an 8 hour work period, and a 4 hour rest period, either whole or divided into intervals. Since it's officially Friday, and you have to have it done by Sunday to be ready for Monday, you have until midnight Sunday, barring the need for sleep or an early departure Monday.
Figuring as of 2.5 hours ago, you have 24 hours today, 24 hours tomorrow, and 24 hours Sunday, for a total of 72 hours. 72/12 = 6, so there are 6 total work days between now and Sunday.
You've got time... pace yourself, don't rush.
Old 09-18-2009, 02:37 AM   #368 (permalink)
Dartmouth 2010
SVOboy's Avatar
Departure is actually sunday
We'll see, I'm trying not to think too hard about it, really.
Old 09-18-2009, 12:40 PM   #369 (permalink)
Dartmouth 2010
SVOboy's Avatar
Today's tasks: Finishing the mounts and hopefully the wiring. We'll see!
Old 09-18-2009, 12:58 PM   #370 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
So, if you gotta U-haul the CRX to school, then you gotta log the 6-8mpg of the hauler in your fuel log as a penalty for not finishing
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
