Old 09-18-2009, 01:07 PM   #371 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
A more likely solution is that the car doesn't come to school with me at all, as I'll have no where to put it or work on it if it's not up and running
Old 09-18-2009, 01:11 PM   #372 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
NO! Don't make me come back down there! I know you can do it!
Old 09-18-2009, 06:56 PM   #373 (permalink)
Dartmouth 2010
SVOboy's Avatar
Do you think I need to put something on the top of this mount to brace the two sides together or not?
Working on the third mount right now, just waiting for the metal to get cool enough for working on it. Might be a tricky one to get on but I'm hoping it'll be solid.
Old 09-18-2009, 07:00 PM   #374 (permalink)
90 day: 51.82 mpg (US)
It would stiffen it laterally. That mount resists up & down movement mostly, I'd say - it looks like it's oriented to take torque from the drivetrain.
But it couldn't hurt to stiffen it for sideways too.
Old 09-18-2009, 08:13 PM   #375 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
I wouldn't worry about any side to side braces on the back mount. The two side mounts will carry most of the load. I believe you were telling me you drove how many thousand miles without one anyhow
Old 09-18-2009, 08:33 PM   #376 (permalink)
Dartmouth 2010
SVOboy's Avatar
I'll probably leave it for now, got other tasks to accomplish. I think I've determined that the ECM power issue is indeed a power issue and not a ground issue. Gonna take a break and eat and hope my headache goes away and try to make a to do list before I head back out to wire stuff up.
Third mount is basically done, just need to weld it to the car, which I'll probably leave for tomorrow when I can see better.
Old 09-18-2009, 09:47 PM   #377 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Yeah, if you want to longitudinally brace that mount, a tab across the top of it will do fine.
I wouldn't worry too much about it, though. What you'll really want to do with your custom mounts is periodically check them for stress cracks, etc... once you determine where/if the failure points are, you'll be able to properly reinforce them.
How far did you get tracing that wire?
Old 09-19-2009, 12:24 AM   #378 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
If the ECU works when you run a +12V wire to it, then run a wire to it for now, and figure out why you had to later.
I'd say get the engine mounted, cobble together the minimally sufficient amount of wiring, and load up enough deep cycle batteries to get you to school.
Old 09-19-2009, 12:28 AM   #379 (permalink)
Reminds me of when I bought a car once... "Dad, how do I get it home... there's no seat in it"
Dad:
"Find a good sized rock, cinder block, couple of bricks, milk crate, whatever... I've got stuff I gotta do, and don't have enough time to bring you a cushy butt-bumper."
I almost agree with this, though - because then you can still work on it while you're at school. Hell, you might just be able to recruit some other students to help you out, as well.
Old 09-19-2009, 09:45 AM   #380 (permalink)
Left Lane Ecodriver
It would amuse me to see an Insight engine fitted with an emergency carburetor, but since you need the ECU to run the ignition system anyway, there's no point.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
