Old 09-26-2008, 12:50 PM   #221 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Phil: So far the MIB have been leaving me alone. Maybe they feel some affinity to me for driving a black car.
Schultz: good idea. I think I still have the mirror & mount from the red ForkenSwift car.
Weather was pretty ideal this AM (light winds) so I headed out to my test route for an A-B-A comparison.
Unfortunately, the replacement cruise control crapped out before I finished the B runs. I kid you not. The first unit worked fine for a year (?) before becoming unresponsive; the second one worked for less than an hour. Same symptoms.
So here's the incomplete data @ 55 mph (88.5 km/h), where A = Kammback on; B = Kammback off. Units = mpg (US)
Code:
Run ... East ... West ... Average
A1 .... 60.9 ... 57.7 ... 59.3
A2 .... 60.4 ... 59.4 ... 59.9
A3 .... 61.2 ... 56.4 ... 58.8
Average of A runs = 59.3
B1 .... 57.2 ... 56.5 ... 56.9
B2 .... 57.6 ... 54.9 ... 56.3
... cruise control stops working ...
Average of B runs = 56.6
No conclusions should really be drawn from this, because it's incomplete. But looking @ just the available figures, the Kammback runs were 4.9% better than the non-Kammback runs.
I really ought to get something to measure sound as well, because there seemed to be a noticeable difference in wind noise between the A & B runs.
Old 09-26-2008, 01:13 PM   #222 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
I'm starting to consider this a plausible addition to my protege5 hatchback... I like the plexi one next door.
Old 09-26-2008, 02:48 PM   #223 (permalink)
incomplete
Darin,the incomplete data set looks very promising.I would like to think that after the cruise-control issues(bummer!) are resolved,that the mpg trend will resurface.The Metro looks really good.If bondo lived down the street,he could pull a mold off the back of the car and reproductions could be layed-up for those with Metros that don't have the facility to do it themselves.If I didn't know what was going on,and just saw your car in passing,I'd presume it was an OEM or SEMA aftermarket part.Seamless!
Old 09-26-2008, 09:47 PM   #224 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Noise can be a surrogate parameter for turbulent drag. Turbulence is noisy.
Much lower noise was how I knew I wason the right track with my bed cover. That funky-looking thing I have is very quiet. An open bed roars at you.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 10-06-2008, 02:07 PM   #225 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
ooo - I totally missed this thread
Metro, some reading for you on moldless sandwich construction by Burt Rutan (you know, the spaceshipOne guy )
http://www.actechbooks.com/products/act431/
Unfortunately, I haven't found a digital copy - check your library.
As for your earlier comment on the black paint showing ripples and such... You're totally right - it's just more time (and some fairing putty) to get it smooth. Using proper sanding implements (sandpaper glued to a long straight 2x4 and implements that match the curvature of your rounds) helps a whole lot - necessary, even.
Because I'm thinking about it (recently saw this in application) - a cheap way to add stiffeners to compound curves is to use foam tape or adhesive weather stripping - then glass over that. The foam conforms nicely and is available in a bunch of thicknesses (bonus for lightweight and cheap)
It looks great though - congratulations Of course, the creator is also the most critical.
And if you didn't think about this already - you now have a working prototype to make a mold and tool from I'm not precisely sure how big the market would be though
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 10-10-2008, 03:48 PM   #226 (permalink)
Pipina - '93 Honda Civic CX
90 day: 46.88 mpg (US)
could someone do the ideal teardrop thing with a 92-95 civic hatch thats stock (not the aerocivic)
Old 11-30-2009, 11:20 PM   #227 (permalink)
White Wocket - '98 Chevy Metro LSI
Last 3: 31.74 mpg (US)
If this turns out well, I was thinking I could make a mold and produce copies for people, but shipping would be a problem! Not really practical.
I'd buy one for sure!! Let us know if you decide to make them for people.
Old 03-27-2010, 02:38 PM   #228 (permalink)
Mirage - '93 Mitsubishi Mirage ES
90 day: 41.92 mpg (US)
Anyone have the tear drop image file? I want to do my car.
Old 03-28-2010, 01:36 PM   #229 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 31.38 mpg (US)
This is awesome, I wish I could make mods look that pro on my car.
Old 05-08-2010, 04:58 AM   #230 (permalink)
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
I want to do this to my 300 SDL. It would be a lot less of a hassle given that there is no hatch; it's just a matter of assuring that the trunk can open all the way. As much as I would hate to drill holes into that car, it already has rust around the trunk area so I doubt it would ever make financial sense to restore the car anyway. The improvement you have gotten based on your results so far, while not scientific due to the incomplete testing, is still obvious. A 3% or higher gain can certainly be expected, but I think the completed results will be more closer to 5%.
Thanks for putting together a very clean addition for us all to oggle at and envy! It's pretty.
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 07:04 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 01:21 AM
