Old 04-15-2016, 01:13 PM   #511 (permalink)
I'd always thought this was possible; probably from seeing this years ago and then forgetting the source.
https://en.wikipedia.org/wiki/Schlieren_photography
Colour schlieren image of the thermal plume from a burning candle, disturbed by a breeze from the right.
The new develpment is that it has sprung from the confines of the wind tunnel, due to new image processing capabilities.
Shock waves produced by a T-38 Talon during flight using analog background-oriented schlieren from the Sun's edge
aerohead (04-16-2016)
Old 04-15-2016, 07:41 PM   #512 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I've seen this used before. I asked about something similar here as well. I noticed that i could literally see the heat waves on my car one day in it's shadow.
The light conditions have to be just right, but it made me hopeful.
It was a very hot day, with the mid-day, to late afternoon sun from behind me.
The Following User Says Thank You to Cd For This Useful Post:
Old 04-16-2016, 06:58 PM   #513 (permalink)
I still haven't found one of the B-2 that is awesome, but this showed up on Guns, Oil and Dirt:
Guns, Oil, & Dirt : Photo
They had to get just the right sun angle for the rainbow, and the super-cavitation off the control surfaces is definitely a bonus.
Cd (04-16-2016)
Old 04-20-2016, 08:03 AM   #514 (permalink)
The Challenge of Standardizing Aerodynamic Testing
May 2015, TruckingInfo.com - Feature
by Jim Park, Equipment Editor
The Challenge of Standardizing Aerodynamic Testing - Article - TruckingInfo.com
In a coast-down test, the test truck is run at a predetermined speed, usually 65 mph, and on a straight, flat section of track, the truck is placed in neutral and allowed to coast down to some predetermined speed. Measurements are taken to determine the relative impact of rolling resistance and mechanical drag (usually constant) and aerodynamic drag (variable with speed). The test requires 20-30 runs and each is measured, compared and averaged along a curve.
aerohead (04-21-2016)
Old 04-20-2016, 11:49 AM   #515 (permalink)
I found the picture I mentioned in Permalink #513.
It was in a catch-all folder so I don't know the provenance.
Old 04-21-2016, 04:02 PM   #516 (permalink)
Aerodynamics of Heavy Vehicles
An Error Occurred Setting Your User Cookie
We present an overview of the aerodynamics of heavy vehicles, such as tractor-trailers, high-speed trains, and buses. We introduce three-dimensional flow structures around simplified model vehicles and heavy vehicles and discuss the flow-control devices used for drag reduction. Finally, we suggest important unsteady flow structures to investigate for the enhancement of aerodynamic performance and future directions for experimental and numerical approaches.
aerohead (04-22-2016)
Old 04-21-2016, 09:00 PM   #517 (permalink)
If you click on anything, they ask for $32.
Old 04-25-2016, 07:55 AM   #518 (permalink)
Yea, it's a paper for sale I guess.
Using one or the other's author names in a Google image search shows several of the paper's images - though they are small.
Same guys did the Flying Fish studies for a Wing In Ground Effect (WIG) aircraft.
Haecheon Choi,1,2 Jungil Lee,2,3 and Hyungmin Park1
freebeard (04-25-2016)
Old 04-26-2016, 06:25 AM   #519 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
From the SafeAuto car insurance commercial...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (04-26-2016)
Old 04-26-2016, 08:30 AM   #520 (permalink)
Time to put bird feathers on your old hatchback apparently - 19 percent reduction in drag?
A bio-inspired device for drag reduction on a three-dimensional model vehicle
Dongri Kim1, Hoon Lee1,3, Wook Yi1,4 and Haecheon Choi1,2
http://iopscience.iop.org/1748-3190/...re/bbaa176ff11
Abstract
In this paper, we introduce a bio-mimetic device for the reduction of the drag force on a three-dimensional model vehicle, the Ahmed body (Ahmed et al 1984 SAE Technical Paper 840300). The device, called automatic moving deflector (AMD), is designed inspired by the movement of secondary feathers on bird's wing suction surface: i.e., secondary feathers pop up when massive separation occurs on bird's wing suction surface at high angles of attack, which increases the lift force at landing. The AMD is applied to the rear slanted surface of the Ahmed body to control the flow separation there. The angle of the slanted surface considered is 25° at which the drag coefficient on the Ahmed body is highest. The wind tunnel experiment is conducted at Re H = 1.0 × 105–3.8 × 105, based on the height of the Ahmed body (H) and the free-stream velocity (U ∞). Several AMDs of different sizes and materials are tested by measuring the drag force on the Ahmed body, and showed drag reductions up to 19%. The velocity and surface-pressure measurements show that AMD starts to pop up when the pressure in the thin gap between the slanted surface and AMD is much larger than that on the upper surface of AMD. We also derive an empirical formula that predicts the critical free-stream velocity at which AMD starts to operate. Finally, it is shown that the drag reduction by AMD is mainly attributed to a pressure recovery on the slanted surface by delaying the flow separation and suppressing the strength of the longitudinal vortices emanating from the lateral edges of the slanted surface.
Yes, another paper available for purchase.
aerohead (04-26-2016), BamZipPow (04-26-2016)
