Old 08-17-2008, 12:24 AM   #51 (permalink)
pint's Avatar
Bertha - '00 Toyota Land Cruiser
Great thread. I can't wait to see how this turns out!
Old 08-30-2008, 08:22 PM   #52 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Sorry guys I really wish I had gotten to work on this a heck of a lot more; however at this point I'm boarding up the house + packing up to run away from Gustav.
Bilge pump does work; however poorly. I want to find a pc water cooling pump.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 08-30-2008, 09:21 PM   #53 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Have a safe evacuation!
Old 08-31-2008, 01:31 AM   #54 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
Dremd,
between dodging Pontiacs and hurricanes you have had a tough summer
hang in there - projects are secondary
God speed
Concrete
Start where you are - Use what you have - Do what you can.
Old 11-10-2008, 12:29 AM   #55 (permalink)
EV OR DIESEL
Another Option Seat Cooling
Saw them at SEMA; talked to 2 random people who had them in their vehicles in Houston and were satisfied.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 11-10-2008, 12:54 AM   #56 (permalink)
Sequential
Concrete's Avatar
Dremd,
looks like a good prospect
my cool or heat seat is dead - mechanics I think are okay - but cover falling apart/off
I was rolling around something like your link in my mind
maybe next summer?
Did you get any comments on the noise of the the fans?
Concrete
Old 11-10-2008, 12:58 AM   #57 (permalink)
EV OR DIESEL
I did not; I was browsing the new products showcase, and 2 guys walked by saying something along the lines of "there's the one we install" I got like 15 seconds before they were gone.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 11-10-2008, 09:30 AM   #58 (permalink)
Mechanical Engineer
The Truck - '02 Dodge Ram 1500 SLT Sport
90 day: 13.32 mpg (US)
The Van 2 - '06 Honda Odyssey EX
90 day: 20.56 mpg (US)
GoKart - '14 Hyundai Elantra GT base 6MT
90 day: 32.18 mpg (US)
Godzilla - '21 Ford F350 XL
90 day: 8.69 mpg (US)
I know it's not the time of year most think of seat coolers but just got into this thread and wanted to throw out a few ideas...
Flojet - ITT Flojet is a maker of pumps that are a little more industrial and larger than other suggestions I've seen and probably cost a bit more, but they're quiet and have published pressure/flow ratings (you can e-mail them for a pressure/flow curve once you select your configuration) and they sell in both AC and DC applications. I'm a bit familiar with their product as one of the machines I work on at work uses these.
Taking the function of that machine and I saw a natural extrapolation into the seat chiller. I don't know about silicon (doesn't that have very good thermal insulation properties?), but I am familiar with Tygon (tygothane) tubing. My only concerns there would be preventing the tube line from getting squished off closed from sitting/leaning on it. A harder nylon tubing might be good from a heat transfer standpoint, but it is *hard* and might be a pea to a few princesses.
Using this pump you could pull water in from a cold sink and pump out to a tee. One branch of the tee has a flow control valve and circulates through the seat and dumps back into the cold sink. The other branch of the tee is the bypass and dumps back into the cold sink. If the pressure/flow requirements of the seat circuit don't line up with those of the flow control you can put the FCV on the bypass, but then the adjustment is intuitively backwards (open the valve to reduce seat flow and vice-versa).
Additionally I was thinking the ice/cooler as a cold sink isn't really necessary if the vehicle has A/C already. It is possible to run the A/C in a manner to minimize the FE hit, so go ahead and run it on recirculate mode on the lowest fan setting. Wrap a copper line around the evaporator coil and use that as your cold sink. Just tie one end of the copper to the pump inlet and take both your seat return and bypass lines into a tee on the other end of the copper line. Your evaporator will get cold but the refrigerant low pressure switch will cycle the compressor off to prevent freeze-up. Getting the compressor into this cycle-off mode minimizes compressor run-time but still keeps the evaporator cold, allowing your seat heater to work. Insulating the lines between the evaporator and the pump and in the bypass circuit should help keep the fluid cold so you aren't pushing heat onto the evaporator unnecessarily.
How about a loop of tube with a sleeve over it you could pull over each shoulder and run down your neck? Cooling your jugular will cool you off fast. Just need a loop on each side with a stiffener/wire in it so that it hold its form where you put it (nothing to choke you of course).
Side benefit of this system is it could work as a seat heater when the A/C is off and the heater is on. The hot air in the blower housing would heat the water which you could pump into your cold seat. Doesn't help until the heat is blowing, but would still be faster than waiting for the cabin to warm.
Old 11-10-2008, 09:27 PM   #59 (permalink)
Sequential
Concrete's Avatar
MechEngVT,
you do bring a good point to mind - using existing systems better
what if you ducted a small amount of air (AC/Heat) to your seat
all it would take is some tubing & an bit of plastic mesh like in Dremd's link
Seat Cooling
it would get you warmer or cooler faster
and even if you did not have AC you would get some evaporative cooling (sweat)
and maybe no more sticking to the seat
the whole system would be much simpler than what we have been discussing
because it would just piggy back on what is already in the vehicle
controls/fan/power supply are all waiting to be used
just a thought
Concrete
Old 04-21-2009, 06:55 PM   #60 (permalink)
EV OR DIESEL
Project is back on!
I wish it was already working!
Going to collect parts for the next 2 weeks until I get a weekend off.
The Bilge pump I used last year is now dead (was 10+ years old already).
I'm considering the 500 pump here Attwood V-Series Charts because it can be had for $17 at wallmart. I'd rather a PC cooling pump, but this is soo much cheaper.
I think I'm going to re-build my heat spreader (tubes in seat) using much much more tubing and 4 "6 way" drip irrigation splitters.
So basically
<aquarium tube>
<aquarium tube>
<aquarium tube>
(Seat back) 6way split<aquarium tube> 6 way split>
<aquarium tube>
< aquarium tube>
Pump- 3/4" tube-T< T-Return tube
<aquarium tube>
<aquarium tube>
<aquarium tube>
(Seat seat) 6way split<aquarium tube> 6 way split>
<aquarium tube>
< aquarium tube>
That should give me about double flow capacity and should get the cheaper pump out of surge and spread the heat out better for a similar total cost + amp draw of a PC cooling pump.
Can anybody think of a small cheap radiator that might fit in my A/C duct?
Or should I just try and wrap some copper tubing around the return line?
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 02:30 AM
Beaded Seat Covers Are Cheap, Keep You Cool SVOboy EcoModder Blog Discussion 48 03-02-2009 03:15 PM
Do Metros have back seat belts & do child seats need to be installed on a seat Wayneburg General Efficiency Discussion 8 05-07-2008 01:11 PM
Budget chevy lumina project. ihatejoefitz Introductions 4 04-19-2008 06:41 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
