Old 11-17-2023, 03:13 AM   #41 (permalink)
...build a house[,] and poop in the street...
Disambiguates whether the house is in the street.
We live in a gutless society where nobody will say anything unless it's...within the terms of service. It's The Lounge, let's test.
Hebraic **** are Semitic; Ashkenazi **** are self-hating Whites.
The wages of woke is broke[™] -- Harvey Cthulhu
Old 11-17-2023, 09:03 AM   #42 (permalink)
It appears in Florida an overlength violation between 2 and 10' is a non-moving violation (no driver points) with a fine of $100 paid on the spot or impounded. The deal breaker however is the vehicle can be prevented from further movement until the infraction is corrected.
Another can of worms I can open, and would lead likely to even greater confusion, if I add any attached trailer, it seems the length requirements upscale to overall combination length of 65' Max.
Guess I might need to build a 3' long uni wheel trailer and put lights and a tag on it, that is liftable for backing?
The Following User Says Thank You to j-c-c For This Useful Post:
freebeard (11-17-2023)
Old 11-17-2023, 11:42 AM   #43 (permalink)
The trailer idea could be thought of as a second trailer. Would need a doubles endorsement?
Way back in the day, I had some questionable stuff on my car that retracted ( curtains across the rear window of a hatchback). When pulled over for a violation, while the occifer was writing up the ticket, I folded them full open. No more violation right then. Sometimes I had to totally remove them from the curtain track, but whatever.
Old 11-17-2023, 01:31 PM   #44 (permalink)
I experimented with the idea with an old tow bar.
j-c-c (11-18-2023)
Old 11-17-2023, 02:53 PM   #45 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Which in the case of a commercial tail would just require you folding up the panels, driving down the road, and then redeploying them.
You can also attach a fork truck to the back and be allowed 50 ft overall length.
The Following User Says Thank You to JSH For This Useful Post:
j-c-c (11-18-2023)
Old 11-18-2023, 03:32 PM   #46 (permalink)
50 ft is a wee bit less than 65 ft. Can you exceed 65 with a piggyback forklift and no oversize signs, permits, or warning vehicles? Don't think so but there may be f650 crew cab and 5th wheel combos that do
Old 11-18-2023, 09:24 PM   #47 (permalink)
I'm still laughing.
Old 11-18-2023, 09:42 PM   #48 (permalink)
JSH
AKA - Jason
JSH's Avatar
50 is less than 65 but JCC just wants to be allowed 45 feet.
No. A straight truck with a piggyback forklift is only allowed 50 ft overall length.
j-c-c (11-19-2023)
Old 11-19-2023, 12:30 AM   #49 (permalink)
I also don't want to crossover from an RV class into Commercial Vehicle regs, which would be draconian in this context.
I thought I had mentioned prior, Fla RV statues clearly states elsewhere two axle RV's are controlled in length by Straight truck statues, 316.515.3a.
A three axle RV is allowed 45' length as per RV statues, and nothing is mentioned about any exemptions with energy conservation devices on 3 axle RV's.
Old 11-19-2023, 01:59 AM   #50 (permalink)
Tag axle with 12" wheels under the back bumper? Wheelie bars?
j-c-c (11-19-2023)
