Old 12-28-2009, 11:04 PM   #21 (permalink)
recession proof rebel
k.civic.f4i's Avatar
man o man. i hope you are still planing on meeting up. id love to see how you did this in person
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 12-29-2009, 12:28 AM   #22 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Any day after the 11th.
Old 12-29-2009, 09:34 AM   #23 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Nice work! Thanks for posting all the pics and adding your lessons-learned construction tips in the first post. I especially like the screen mesh covers over exhaust bits. Keep us informed if you notice any problems or discoloration of the coroplast. You have avoided the catalytic converters, where the real heat is, so I don't anticipate any trouble.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 12-29-2009, 03:47 PM   #24 (permalink)
mcrews's Avatar
Thank you for the kind words.
I am almost finished with the last 10%!!
Old 04-08-2010, 01:21 AM   #25 (permalink)
Any thought of using aluminum window screen rather than that courser screen? Maybe a bit less draggy. OTOH, you already have a screen done and fitted.
Old 05-08-2010, 04:01 PM   #26 (permalink)
MrMiata's Avatar
78 Olds Cutlass - '78 Oldsmobile CutlassSupreme
Big Red - '10 Toyota Venza AWD
This give me the incentive to get started on the Matrix.
Great pics. and explanation of install.
Old 05-09-2010, 12:42 AM   #27 (permalink)
mcrews's Avatar
Mr Miata,
Thanks for the kind words!
It was much bigger than I thought!!! I love to do something smaller like the Matrix.
The Following User Says Thank You to mcrews For This Useful Post:
MrMiata (05-09-2010)
Old 05-09-2010, 05:38 PM   #28 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Why couldn't an ecomodder use sheet metal or aluminum instead of flammable coroplast? On my Maxima the exhaust system is insulated (but not the cats) so covering the entire exhaust system and cooling just the cat should in theory be acceptable. I'm also considering installing ground effects on the sides and fronts then putting the underpan at that level which would keep the metal away from the heat, and assuming I leave enough air flow into the engine compartment it should be kept cool if I make it airtight.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 05-09-2010, 05:51 PM   #29 (permalink)
mcrews's Avatar
Read some of the older posts on underbellys.
Everybody starts with something different and ends up with .......COROPLAST!!!! lol
1. lightest weight for all possible products
2. cheapest cost for all possible products
3. easiest to work with for all possible products
4. causes least amount of damage WHEN something jumps up under your car at 65mph.
(6 feet of semi-truck tire tread cam flying uot of nowhere and went right under the car!!!!)
Alum will vibrate if too thin......if too thick not to vibrate is too expensive and too heavy.
CP is actually pretty ridgid and doesnt take alot of mounting points.
I have had ZERO problems since I installed back in Nov.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-10-2010, 10:23 PM   #30 (permalink)
mcrews's Avatar
re-did the front underbelly pan.
removed the 'rubbery' panel material and went with the "solid" scrap of coroplast-like material that I had left over from the rear section.
here is a close-up of the edge of the material.
also a close-up of the factory deflectors for the front tires that were on the origianal factory underbelly pan..
ECO MODS PERFORMED:
First: ScangaugeII
MrMiata (05-11-2010)
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
