12-29-2014, 08:45 AM
#1851 (permalink)
Rat Racer
YKYAEM if the speed limit on the local highway just went up 10 mph and you're the only one in the area who isn't excited.
And the reason you're not excited is because you know that nobody's going to get where they're going any sooner than before. There'll be less fear of tickets, but not much in the way of increased overall speed- especially through the chokepoints where this will probably be counterproductive.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
01-17-2015, 04:26 PM
#1852 (permalink)
Lots of Questions
YKYAEM when you see a pinewood derby blank and your first thought is "how would I aeromod this?".
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
01-17-2015, 07:05 PM
#1853 (permalink)
Ha! I've actually thought about that, here is what I came up with:
super low profile, only as tall as the wheels
reverse trike
the wheels ground down to be super thin (lrr)
plus the max weight achieved through integrated weights (more momentum)
"Ignorance is bliss, but only for the ignorant"-Hypermiler1995
01-18-2015, 01:34 PM
#1854 (permalink)
aero guerrilla
YKYAEM if...
... Noting your trip and tank milage, average speed, fuel consumption, etc., and reseting your trip odometer, on-board computer and ScanGauge, then filling out spreadsheets at home and logging the milage online, takes much more time than just filling up.
The Following User Says Thank You to Piwoslaw For This Useful Post:
01-18-2015, 02:17 PM
#1855 (permalink)
ALL UP ON THE INTERWEB!!!
Originally Posted by Piwoslaw
YKYAEM if...
Can't forget adjusting mpguino! Recalibration math with 10 digit multipliers. Non - modders just don't get it!
Thanks,
Victor
01-19-2015, 08:58 AM
#1856 (permalink)
Thanks,
Victor
Ah, the old 5-digits-more-than-your-measurement-error trick, huh? YKYAEM when you know how big to draw the error bars on your mileage graph
01-19-2015, 10:25 AM
#1857 (permalink)
Rat Racer
YKYAEM if...
Due to a long day at the end of a long week in blow zero temps, You fail to jot your tank mileage on your hand (the pump didn't print a receipt) before resetting the trip odometer.
And you can solve it by checking your fuel log here and subtracting your log's mileage from your current numbers.
01-19-2015, 01:26 PM
#1858 (permalink)
YNYAEM . . . .
If you've owned your car for six months and you have over twenty mods, and you're contemplating modding some of the mods . . . . .
If you're still pushing yourself for best tanks even though gas is under two bucks a gallon and you're spending less than ten bucks a week on it . . . . .
If you could air up a semi tire with the air from your 165-65-14 LRR tire. . . . .
01-29-2015, 12:55 PM
#1859 (permalink)
YNYAEM.....
When the boys at the parts counter see you coming and know the parts you want don't go to the application, so the computer's no help & the books come out
01-29-2015, 08:06 PM
#1860 (permalink)
YNYAEM.....
Ha! That's basically me in any store... whether it's a supermarket, looking for cutting boards of a specific thickness, a hardware stores looking for brass converter fitting with a particular diameter ratio on the internal step, whatever. I was in a bead shop the other day asking about beads in primary colors, that don't roll easily  ...
