09-19-2018, 08:24 PM
#121 (permalink)
The bullet nose was 1950-51. The shark mouths are big compared to the Ghia. If more air flow were needed, I'd go with two more Ghia grilles turned upside down below the originals.
Sounds like a good idea.
09-24-2018, 10:00 PM
#122 (permalink)
Hoopie
Video update
The Following 8 Users Say Thank You to Hoopie For This Useful Post:
09-24-2018, 10:09 PM
#123 (permalink)
Have to admit, the first thing that went through my mind after seeing you tooling around the parking lot in the stripped Prius chassis (after: "Cool! Fun!") was...
Blank slate for a low-drag custom body!
09-25-2018, 01:13 AM
#124 (permalink)
Drone shots!
That is so cool. I agree it's almost a perfect donor vehicle. If you did a batch of Prii, how many hours to bring each one to this point?
Don't hesitate to cut the wheel openings, Ghias typically overhang the tire anyway. Raised flares and an airdam would tie it all together.
ALT Series: The Karmann Ghia - Speedhunters
I made fender flares of a VW bus once by having a sheet metal shop cut a sector* of a circle that I bent into a sector of a cone and riveted it on. On a Ghia you'd have to order a wide sector and trim the outer edge to fit.
*Sector or segment? I'm thinking of a partial ring.
09-25-2018, 06:52 PM
#125 (permalink)
Hoopie
I think 6-8 hours. Obviously it could be faster with practice. There’s a learning curve.
The Following 2 Users Say Thank You to Hoopie For This Useful Post:
09-25-2018, 07:39 PM
#126 (permalink)
Originally Posted by Hoopie
That's going to work out nicely! Love the video! It brings back memories!
Bill
The Following 4 Users Say Thank You to Bill the Engineer For This Useful Post:
09-26-2018, 08:54 AM
#127 (permalink)
Cyborg ECU
Holy wow. That video update is amazing. The fit is so good. You make it look easy but we all know it is quite difficult. Beyond my skills by an order of magnitude or two. Fun.
09-26-2018, 12:40 PM
#128 (permalink)
... that it looks even better than a Prius
The Following User Says Thank You to euromodder For This Useful Post:
09-26-2018, 03:12 PM
#129 (permalink)
I believe I can get the cowl down far enough for the Ghia front clip. I may need to put lowering springs or air ride on it to get the ride hight correct.
probably all over bar the shouting by now, but I think I would have put the Prius power plant where the back seat is for a mid engine design, and battery in the front
09-26-2018, 03:20 PM
#130 (permalink)
Bill
have to admit it seems to be going quite well
air dam and an under tray and your laughing
The Following User Says Thank You to sidecar For This Useful Post:
