Old 08-04-2010, 07:52 PM   #1 (permalink)
Alty-magnet - '06 Altima SE
90 day: 33.83 mpg (US)
maxi-magnet - '97 maxima gxe
90 day: 26.46 mpg (US)
Using Magnets to increase milage
Last year I posted a thread about increasing milage using high powered magnets. I stated I would do a A-B-A test.
I am still getting 34-35 mpg with ethenol fuel. I did an A-B-A test. The milage stayed the same when I took off the magnets.
My conclusions are that the magnet conditions the fuel and the ECU senses the change and adjusts fuel delivery rate to compensate. As the magnets clean out the combustion chamber, it would take thousands of miles to return the carbon buildup and varnish to make the ECU return to orginal mode.
I believe the fuel we pump is stale and contaminated with particles from air and tank like leaving fuel in a lawnmower over the winter. I think the magnet restores the fuel to original form, expanding it, then the ECU senses it and reduces the fuel flow.
Old 08-04-2010, 08:29 PM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
A-B-A test show no difference with fuel rail magnets. Fuel rail magnets don't work.
If you had stopped there, I would have nothing to disagree with.
If you try some studies outside of a car, I think you'll find magnetic fields have little to no impact on fuel. Further study will demonstrate that fuel filters, before and after the fuel pump, remove the particulates you mentioned.
Here's one for you. Stick a magnet on cylinders #2,4 fuel injectors. Pop the cylinder head off in two years, and I'll bet you dollars to donuts there's no discernable difference in combustion chamber cleanliness.
The Following User Says Thank You to RobertSmalls For This Useful Post:
Frank Lee (08-07-2010)
Old 08-04-2010, 08:33 PM   #3 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Villager gs
90 day: 19.8 mpg (US)
Max - '98 Maxima SE
90 day: 26.89 mpg (US)
only way magnets help gas mileage is if they are part of an electric motor.
Gotta love wife, kids, and car!
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
The Following 3 Users Say Thank You to ShadeTreeMech For This Useful Post:
PaleMelanesian (08-05-2010), Piwoslaw (08-05-2010), will88 (08-22-2010)
Old 08-04-2010, 08:36 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...actually, the *best* use of a magnet in the pursuit of fuel-economy, is to use one to hold your SGII securely onto the dash for easiest viewing.
The Following 5 Users Say Thank You to Old Tele man For This Useful Post:
mcrews (08-08-2010), PaleMelanesian (08-05-2010), Piwoslaw (08-05-2010), ShadeTreeMech (08-05-2010), Weather Spotter (08-04-2010)
Old 08-04-2010, 08:50 PM   #5 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
junk
I think that magnets are a not going to work, else they would come new that way. the chemistry also does not work that way. if in that short of time it can change the molecular shape they in the same time it will move back.
Old 08-04-2010, 08:57 PM   #6 (permalink)
Bus - '94 School Bus huge
Stupid - '01 Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Superhawk
I think that you would find that the magnets would destroy the injector, an electro magnet.
Old 08-04-2010, 09:19 PM   #7 (permalink)
Gen II Prianista
Rokeby's Avatar
Maybe this would work:
(I think it's been PhotoShopped. )
Old 08-05-2010, 12:46 AM   #8 (permalink)
Yeah. The only way you're going to increase mpg with magnets is to mount one on a long pole (perhaps telescoping?) sticking out the front bumper, then drive close enough behind a semi that you can "latch on" to it.
Which might even be a safe way of drafting, if the pole had some shock absorbing capability...
The Following User Says Thank You to jamesqf For This Useful Post:
Old 08-05-2010, 02:26 AM   #9 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Legacy Wagon 2.5 GT
Last 3: 23.78 mpg (US)
Maus - '94 Civic VX
90 day: 54.33 mpg (US)
Helga - '00 Jetta TDI
90 day: 57.68 mpg (US)
I believe you will believe whatever you want to believe in order to believe that the magnets work...
Old 08-05-2010, 06:34 AM   #10 (permalink)
Chug - '96 Polo CL
90 day: 49.42 mpg (US)
I can't see how magnets could be used to 'condition the fuel' if there was enough effect on the particles to pull them into alignment (as some of these wonder things suggest) surely cars would suffer huge amounts of fuels starvation and pressure spoting from fuels passing close to Hi ouput electrics, like the start solenoid, alternator or starter motor etc.
Also i have to agree about the a-b-a thing. If you add something on the B test and nothing changes, ITS NOT HAVING AN EFFECT. if it did change from a-b but stayed the same b-a then it was a purely placebic change like an improvement in your base driving style.
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Anyone using magnets to increase milage? hondo434 The Unicorn Corral 228 03-29-2012 12:21 PM
Magnetic engine returns BillWhedon The Unicorn Corral 21 04-21-2009 09:57 PM
Magnets (as attachment method) jmonroe Aerodynamics 10 03-07-2009 01:12 AM
New Report of 20% milage increase by reducing viscosity of fuel htaylor EcoModding Central 29 01-27-2009 12:35 AM
magnets use for permanent mods ? groar EcoModding Central 5 09-08-2008 03:52 PM
