Old 12-02-2014, 06:15 PM   #631 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Yes - "skid plate" was the first thing that came to mind. :-)
It would be a flat piece curved up at the end facing the rear of the car.
Coroplast should be tough and flexible enough to withstand being banged up - just look at the ones used on the catamaran channels behind the front wheels on the car.
It would get scuffed up - much like a 'skid plate' .
Old 12-02-2014, 10:00 PM   #632 (permalink)
Oh, OK. But were it I, the skidplate would want to be titanium. It's light and has other advantages:
Old 12-03-2014, 09:29 AM   #633 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Not a skidplate so much as a tailskid.
Just a reinforcement to protect against glancing impacts:
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
aerohead (12-03-2014)
Old 12-03-2014, 09:41 AM   #634 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
That's just what I need. Scrape the underside on the road and start a bush fire.
Starting to cogitate a few ideas on how to do this. Thinking hinged at bottom front of existing boattail. Metal bar frame skinned with coroplast for the underside. Frame will be positioned about a foot below the existing boattail at the back end to produce the reduced departure angle and will extend about a foot beyond the existing boattail. Two compression springs at back end to keep frame in down position when not in contact with road. Possibly small wheels under frame at back (wait to see where the coroplast shows road rash). Lower sides made of aluminum sheet with hinged seam (piano hinge)running length of boattail to maintain rigid shape in wind yet fold out when frame contacts road. Hinged aluminum bars to attach back of frame to back of boattail. Don't want to go with fabric sides to the boattail extension as that would likely flutter in the wind unless kept tensioned just right. Any thoughts? It would be illuminating to do a CFD image of the aerocivic with a 10 degree departure angle to see what the flow improvement would be.
aerocivic.com
The Following 2 Users Say Thank You to basjoos For This Useful Post:
aerohead (12-03-2014), BamZipPow (12-03-2014)
Old 12-03-2014, 11:47 AM   #635 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I would lose the small wheels and go with a lower profile wear/scuff plate. Plastic cutting board material works well. Use bolts that have been countersunk into the plastic to secure it.
Never been a fan of piano hinges especially fer things that have a potential flex as the piano hinge flexes, it will start to bind. I've used normal hinges and taped the gap seams with Tyvek tape to keep the gaps covered up while it still allows flexing/pivoting.
When I was building my belly pan and was in the early stages of development of my rear diffuser, I had the diffuser on hinges and a few bungee cords to allow it to hang and thinking that gravity would overcome the air pressure underneath the truck. I was wrong and the diffuser ended up rising/falling based on the air pressure building up which would pushed the diffuser up until the pressure would bleed off causing the diffuser to drop. This banging cycle started around 30mph. I finally set the diffuser in a fixed position and angle but I left the hinges in place as I have a rear wheel drive and needed the flex in the rear. I believe you will probably discover this if you go with a gravity based solution.
You could go with an inner tube/air bladder between the rear diffuser and the bottom of the car body so as you contact the few driveways, it would compress enough to allow clearance and then extend back out to the proper angle. You'll have to experiment with the amount of air pressure that will meet yer needs. You will still have to install some wear skid strips so it doesn't beat up the diffuser too badly.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (12-03-2014), COcyclist (12-04-2014)
Old 12-03-2014, 12:08 PM   #636 (permalink)
It was a joke.
Since the plate has a single degree of movement, the sides could ride up into slots in the boattail or be made in overlapping halves. No need for a flexible cover.
Forget the self-optimizing behavior, make it stout and require 25% of the vehicle (rear axle) weight to move it. That should dampen the aerodynamic oscillations.
Old 12-03-2014, 01:49 PM   #637 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by Cd View Post
Some CFD flow images of the car, and some of a standard car without the aero modifications...
Nice CFD work!
I'm surprised that there is this much flow separation next to the red arrow?? I would expect the flow to stay attached longer in that spot.
Jim.
Old 12-03-2014, 05:45 PM   #638 (permalink)
Cfd
I wish you could have been with me in 1984 at Epcot Center.
At the GM Pavilion,they had their Aero 2000 concept car on display.And they had a video depicting the airflow under the car,with an active diffuser deployed,and with it stowed.
The flow looked really good with the diffuser down.After Darko,I know I need to do something with the T-100.
Old 12-03-2014, 07:43 PM   #639 (permalink)
Cd
Ultimate Fail
Cd's Avatar
As I mentioned previous : "I should add that the CFD images may not be totally accurate, and this entirely due to my lack of understanding of how to use the program.
Sometimes artifacts appeared, and the tests contradicted themselves.
I fully encourage others here that are CFD pros to run professional level testing on the car."
To give you some idea of some of the odd things going on with the CFD, just take a look at this image of the top rear of the car that shows flow separation where we know that there is none.
I would like to see a redo of the CFD done by a professional - there are a few on this site that work in CFD.
I never posted these images due to the inconsistencies in the results, and especially the Cd value.
I tested the CarBEN and ran into the same issues.
( The flow along the bottom appears much less turbulent here as well )
The Following 2 Users Say Thank You to Cd For This Useful Post:
3-Wheeler (12-04-2014), BamZipPow (12-03-2014)
Old 12-04-2014, 08:56 AM   #640 (permalink)
basjoos's Avatar
You're thinking of the cheap, steel, light duty piano hinges sold at the big box home improvement stores. If you look at the range of piano hinges available at McMaster-Carr, you will find mil-spec, stainless, aluminum, titanium, load-rated piano hinges in many thicknesses and widths. I have piano hinges mounted as the hinge point on the top of my wheel well covers where they have been serving for years without trouble.
For the boattail bottom extension, I'm thinking about using coroplast for the flexible sides rather than aluminum sheet. This dispenses with the need for piano hinges and, as my side skirts have proven, coroplast can flex numerous times without fatiguing. Just need to keep paint on it to keep solar UV from damaging it. Although I might want to experiment with using white elastomeric coating rather than paint to protect from UV. Around the farm I've been using it successfully on those gray tarps to extend their life. They normally last about 6 months in the summer sun, but I have a coated tarp in use that's lasted a year so far.
I've got a design worked out. Now just need to source the parts and find the time and weather (I'm working outside) to implement it.
aerocivic.com
aerohead (12-04-2014), BamZipPow (12-04-2014)
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 12:14 PM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 12:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
