Old 06-20-2014, 05:26 PM   #161 (permalink)
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
Thanks Wabbit, I will research the turning vanes
Old 06-21-2014, 12:12 PM   #162 (permalink)
Thanks Donkey! I've never seen one up close, but it looks to me like Mr. Brock used a simple formed sheet of acrylic. If so, one would want the exit area to be a somewhat less than the inlet area, so that the flow inside of the vane would accelerate and have the energy to promote attached flow along the side of the green house. If you had too much inlet area, the flow outside the vane would detach and you might add drag. I think an airfoil shape with as much camber as the windshield to side window angle would be better, or at least forming the sheet into a 180 degree radius at the inlet would be better. That would give the stagnation line some flexibility as to where it lies. A fore and aft, and in and out adjustment could be used to tune the installation, along with some tuft testing.
The Following User Says Thank You to Crazyrabbit For This Useful Post:
The donkey CRX (06-21-2014)
Old 06-21-2014, 03:10 PM   #163 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
The A pillar splitter used in the Shelby Daytona Coupe was to get air to the rear brake scoop.
However I can see where it might warrant testing to see if it can promote attached flow along the side.
2000 Insight MT 106K Citrus A/C
The Following User Says Thank You to WD40 For This Useful Post:
The donkey CRX (06-22-2014)
Old 06-21-2014, 09:20 PM   #164 (permalink)
Rear Brake Cooling
There was a Discovery channel (I think, it might have been Speed) documentary on the cars with Mr. Shelby, and Mr. Brock talking about the cars, and while discussing the turning vanes, they did mention the getting air to the rear brake scoops, but more emphasis was placed on the aerodynamic benefit. I think the brake cooling airflow bit was true, but I think back in the day, that was all they talked about as a way of not being imitated. So they may have added them to get airflow to the rear brakes, but in retrospect it was a significant aerodynamic advantage.
Old 07-02-2014, 11:41 AM   #165 (permalink)
ecoTex's Avatar
green VX - '95 Honda civic VX
90 day: 59.74 mpg (US)
Well Pop, what's next?
My adjustable WAI / HAI build thread
http://ecomodder.com/forum/showthrea...tml#post408134
Old 07-02-2014, 07:58 PM   #166 (permalink)
Gen-1 Insights
Well EcoTex, it may take a few weeks to get started, but I plan to convert the 1988 CRX ( The original Donkey CRX) to the ultimate Aero Honda yet. I will try to document this build from the start with pictures.
Old 07-02-2014, 08:16 PM   #167 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
waiting with anticipation, I have an 88 CRX also. I really like your work and maybe I can get some ideas. Are you going to have a dedicated thread for the CRX?
The Following User Says Thank You to iveyjh For This Useful Post:
The donkey CRX (07-02-2014)
Old 07-02-2014, 08:17 PM   #168 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Xntra was able to buy the moon discs without the spring steel part. I assume they would also be cheaper that way.
Sorry I can't remember where we got them.
Not cheaper, but true spun aluminum. Came from Speedway
Let me know if you need anything.
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following User Says Thank You to Superfuelgero For This Useful Post:
Old 07-02-2014, 08:41 PM   #169 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
I can't wait to see what you guys come up with! I wish you the best, and I'll be reading along. .
The Following User Says Thank You to vrmouseyd15b For This Useful Post:
Old 07-02-2014, 09:28 PM   #170 (permalink)
Gen-1 Insights
Thanks for the encouragement guys. I want to make the CRX even more extreme than the Red VX with a more aero front and a full boat tail. Should be a lot of fun!!
