Old 05-08-2019, 05:48 PM   #5781 (permalink)
Originally Posted by aerohead
*fact-checker isn't something associated with science publication.Science journals employ graduate researchers,veteran Ph.D.s,and veteran post-doctoral experts,in the specific field of study.
And their work is commented by erudite persons. For popular consumption.
*CMEs are plazma:electrons,protons,atomic nuclei....cannot be predicted.By anyone.
*Also,the field strength of Earth's magnetosphere is a function of latitude.It's 15% weaker at the poles.
*Asteroids are orbiting rock,leftover from the accretion disc which formed the solar system.They have nothing in common with CMEs.
*Gamma-ray burst can sterilize Earth and is a great concern,but nothing we have any control over.
*Starting every line with an asterisk levels the distinction between facts, observations and commentary.
*A mininova isn't the same as some asteroids, but has similar effect.
*Earth's geologic record has many accounts of polarity 'excursions',where the field partially reverses,then 'jumps' back to the original dipole orientation.These events cannot be predicted.By anyone.
Recently declassified documents (the Adam and Eve story*) suggest that that happens a lot, but so quickly the geologic record doesn't show it.
*As to ice-ages:the language is:
glaciation [leading edge]
deglaciation [trailng edge]
As per Potholer54's reporting,Ben Davidson has no command of the language of Glaciology.It's not a criticism,just an observation.
Potholer54's effette snobbery doesn't change the fact that S0 gets school kids excited about astrophysics. I doubt he could.
*If you can link to the cyclone video I'll look at it.
Can you give the Permalink where I mentioned it? I can't find it, but I remember pasting the URL at the time it shows and suggested you could close the window after the 10-15 seconds. It was pretty spectacular white water vapor coming down from the cloud and brown dirt coming up from below with a clear section in the middle where they weren't mixing.
____________
I've never met AOC,I don't know anything about her.
Technically we all live in our own head and should be suspicious of everyone else. Especially freshman Congresspersons who think they are in charge because nobody else is doing what she wants (or is told to want).
edit:
There might be a case for the House and Senate being required to use a rigorous scientific metric in the confirmation process for POTUS nominees.It wouldn't matter how lame the president or their nominees were,Congress simply wouldn't be able to install the minion/sychophant/boot-lickers without an extreme portfolio of real qualifications.Not just whether or not they sexually molested someone when they were drunk.
That's asking for a lot. And assumes Congress is less lame that the Executive.
Separation of powers, etc.
As a tangent, why does POTUS get to appoint supreme court justices for life? That job should be just like any other, where we either elect them, or they are internally promoted to the position.
Maybe an occasional head count or requirement for proof-of-life?
*https://www.cia.gov/library/readingr...000300070001-8
aerohead (05-08-2019)
Old 05-08-2019, 06:34 PM   #5782 (permalink)
SO
____________
edit:
*I'll stick to the asterisks as a way to discern between different subjects and make easier to locate.They're bullets and used by many.
*Davidson said nothing of mini novas in the youtube.If you want to preface the video beforehand with these embellishments great.Otherwise one can't be expected to know anything about them.
*Ben never mentioned excursions and neither did you.I can't read minds.
*I'm not interested in your impressions of potholer.It's not germane to SO' content.
*The permalink was maybe three pages back.The link wouldn't work.If you see a cyclone which appears visually,vertically bifurcated,it has to do with the lack of entrainment of water or particulates.The vortex is there,it's just invisible.Sometimes in Reed Timmer's tornado videos the funnels won't be visible until they get low enough to touch ground,otherwise just looking like a scud cloud.
*If you were AOC you'd do exactly what she does.Climate Silence needs to be addressed.Not enough voices if you ask me.81% of registered voter are egging her on.
*Redpoint mentioned appointees.My comment attempted to address the challenge.I'm not a political animal.If Congress had a non-negotiable template that they had to use for the nominee confirmation process,maybe morons wouldn't make it into agencies.
*Yes,at least see if they could fog a mirror.
Old 05-08-2019, 07:18 PM   #5783 (permalink)
[snip]
  • Bulleted lists are a feature
  • They can be used as you describe.
Define my terms? I was responding to yours.
  • free bullet point
______
Climate Silence? What? Is that different to pushback?
I would not use climate anxiety to push communism.
I have no idea about Aton Petrov's credentials. He's another popularizer.
Hello wonderful person! Red dwarf go boom.
aerohead (05-11-2019)
Old 05-09-2019, 06:18 AM   #5784 (permalink)
90 day: 57.12 mpg (US)
I've never seen a hydrogen fuel cell vehicle up close and personal,but it could be,that all available space in the vehicle is already taken up with the fuel cell apparatus,leaving nothing left for even a modest battery pack.
FCVs have large fuel cells and radiators and a small battery. They need large fuel cells to produce enough energy to climb a hill, which would deplete that battery. They need large radiators because fuel cells are notoriously heat sensitive.
A plugin FCV could have much smaller fuel cells, a smaller hydrogen tank (size matters a lot in pressurized vessel costs) and 'normal' sized radiators. That alone would free up enough space for quite some extra battery storage. And electricity will always be cheaper than hydrogen.
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
aerohead (05-11-2019), NeilBlanchard (05-09-2019)
Old 05-09-2019, 11:36 AM   #5785 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
I'm over at the RENEW ECONOMY website.Some really amazing news.
*On 30 April,2019,wind and solar ran all of Australia for nearly 6-hours,pushing prices below zero.
*8 May,2019,In Britain,wind and solar pushed coal off the grid for over 6-days.
*Kennecott's Rio Tinto copper mine,Utah,USA, closes coal plant,and replaces with renewable power purchase agreement.
*Bank of Australia signs power purchase agreement with Crowlands wind farm,becomes first Australian bank to go 100% renewable.
*Australia can be 100% renewable by 2030s says Garnaut.
*Renewables deliver a record 77% of Germany's power on Easter Monday.
Man,the Kool-Aid's great!
Too bad that on average, Germany and South Australia have the most expensive electricity in the world.
The Following User Says Thank You to sendler For This Useful Post:
Old 05-09-2019, 11:43 AM   #5786 (permalink)
sendler's Avatar
In the words of systems theorist Kenneth Boulding: “Anyone who believes exponential growth can go on forever in a finite world is either a madman or an economist.”
https://www.resilience.org/stories/2...ishing-future/
Old 05-09-2019, 11:57 AM   #5787 (permalink)
90 day: 29.78 mpg (US)
Economists of all people should be acutely aware of the limitations of exponential growth.
People that saw housing prices appreciating at a higher rate than inflation year after year, and comprehend the problem of exponential growth saw the impending collapse.
Old 05-09-2019, 06:51 PM   #5788 (permalink)
This from Subverse (this Subverse, not that other one):
Earth's BIGGEST Problem is NOT Global Warming
An intergovernmental group of hundreds of scientists have identified accelerating extinction rates as the biggest problem facing our planet right now. Ecosystems are deteriorating and more species of plants and animals are threatened than ever before in human history.
Old 05-10-2019, 06:13 AM   #5789 (permalink)
sendler's Avatar
What year did South Australia start building out it's wind generation and prematurely retiring thermal production?
Old 05-10-2019, 06:29 AM   #5790 (permalink)
We have been there before, but here goes:
https://theconversation.com/factchec...ble-grid-92928
It is no simple matter, and environmental policies do not play a major role.
Yes, environmental policies weigh harder on South Australia than anywhere else. But the difference is a small fraction of total costs.
lies, opinion, reality, scam
