10-22-2017, 02:59 PM
#471 (permalink)
Cyborg ECU
So thorough. Man, oh man. How many coats of paint? What brand are you using?
10-22-2017, 07:11 PM
#472 (permalink)
Bill the Engineer
The Following 2 Users Say Thank You to Bill the Engineer For This Useful Post:
10-22-2017, 07:26 PM
#473 (permalink)
Continued with the wire brushing and rust converting paint today on the underside of the body. Got back as far as the front edge of the rear seat area today.
The inner part of the rocker panels were NEVER painted by GM. (They didn't dip the bodies back then.) Even so, they were remarkably rust free when I painted them.
Naturally, I already see a spot I missed. Ah well, there's always next weekend.
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
10-22-2017, 08:20 PM
#474 (permalink)
Cyborg ECU
Yes. That's the brand I used for so clear-coat touch-up on my wife's car. They sell an activated clear coat that is almost like having a paint-gun in a can. The best.
10-25-2017, 06:23 PM
#475 (permalink)
First freeze tonight. (All of my joints are already telling me!) Looks like I need to grab any warmish weekend days that I can between now and Winter to work on the project.
Bill the Engineer
10-27-2017, 05:12 PM
#476 (permalink)
Took Friday off because the weather is relatively nice. Saturday and Sunday are supposed to be damp and cold.
Started off the morning working on the new gas door area. My late Dad must be smiling down on me today. His old recess forming pliers worked much better than the pair that I recently bought. The recess is to make the Gen-II Prius gas door fit flush into the fender. I'm a little concerned about the extent of the Bondo skim coat that I am finding though. (TBD if the entire fender is eventually replaced, or just the areas that are bad.)
In the afternoon, I moved under the car to finish the seam welds in the soon-to-be-hidden places. Then I ran out the can of rust converting paint on the areas that will become inaccessible.
All that is left now is a little bit of weld grinding before I can prep things for the body drop. We'll see if the weather cooperates.
Bill the Engineer
The Following 4 Users Say Thank You to Bill the Engineer For This Useful Post:
11-04-2017, 06:28 PM
#477 (permalink)
FINALLY!!!! The last task in the way of putting the body back on the chassis is DONE!!! On the Prius v, Toyota routes the parking brake cable back behind the Denso A/C unit on the far side from the driver. This made the cable too short to reach the new parking brake pedal position on the Firebird firewall. One last bolt behind the A/C unit was keeping the cable in place. It took an hour and a half with my head upside down lying on the floor of the car, and using three different wrenches to get the bolt loose in the tiny little hole I had access through... but I finally got it. The photo is of the cable pulled out from behind the A/C unit and rerouted to the driver's side. Got-cha you little bugger.
Bill the Engineer
11-05-2017, 06:32 PM
#478 (permalink)
The Following 12 Users Say Thank You to Bill the Engineer For This Useful Post:
a8ksh4 (11-06-2017), aerohead (06-19-2020), COcyclist (11-06-2017), Daox (11-08-2017), eco_generator (11-06-2017), mannydantyla (10-22-2018), mcrews (11-09-2017), me and my metro (11-05-2017), nemo (11-14-2017), RedDevil (11-06-2017), roflwaffle (11-07-2017), Xist (11-07-2017) |
11-07-2017, 04:25 PM
#479 (permalink)
You know, I keep visualizing this, but with the Firebird racing towards the Prius,
and then morphing into the Firebrid:
The Following 2 Users Say Thank You to Xist For This Useful Post:
11-07-2017, 07:33 PM
#480 (permalink)
I LIKE that visualization!
Bill the Engineer
