Old 09-21-2010, 07:57 PM   #101 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Update:
I did some rearranging work so that I can reverse the grates back to my original set up. I left the 2x2 on the bottom (ran it the whole way across both grates), and used the same mounting setup for the actuators as in the test run. I just duplicated it for the second one.
From this set up:
All I modified is adding nylon washers on each side of the "L" bracket, a 1x1 on the bottom side of the 2x2 (radiator side) to allow the actuators room to move.
I mounted it up:
I tested it out (last time I had the main epoxy connection break) nothing broke this time!
Then I took it for a test spin to test these things:
1 will the grates stay open at speed. Passed
2. stay closed at speed. Passed
3 will close at speed. Passed
4. will open at speed. Passed
I tested it up to 55MPH and over paved and gravel roads. Total test run 5 miles.
It will get a much better test the next time I go into town.
The Following User Says Thank You to Weather Spotter For This Useful Post:
WesternStarSCR (10-11-2012)
Old 09-21-2010, 09:10 PM   #102 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Awesome!! Very cool!
Old 09-21-2010, 10:03 PM   #103 (permalink)
...beats walking...
...with careful attention, you should be able to A-B-A test "realtime mpg" changes using your ScanGauge on a quiet, straight roadway.
Old 09-21-2010, 10:07 PM   #104 (permalink)
Wiki Mod
that is a great idea, today will not work, winds 30+. Tomorrow is similar.
Old 09-22-2010, 03:02 PM   #105 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Weather Spotter -
Originally Posted by Weather Spotter View Post
I will not wreck my legos by epoxying them!
besides the pivot arm length needed is longer than I have room for (twice as long).
Ha ha, I thought epoxy might be sacrilege, but sometimes you have worn-out Legos that you are willing to sacrifice.
How about Mega-Blocks, ?
CarloSW2
American Solar Energy Society
Old 09-22-2010, 03:06 PM   #106 (permalink)
Wiki Mod
Originally Posted by cfg83 View Post
Weather Spotter -
CarloSW2
Mega- Blocks? What are those? http://forum.ecomodder.com/images/smilies/biggrin.gif
I only have Lego's and I kept mine in great shape, so not broken ones. What I did seems to be working though.
Old 09-22-2010, 03:11 PM   #107 (permalink)
Very cool Weather Spotter! Do you have any plans to automate it?
Old 09-22-2010, 03:17 PM   #108 (permalink)
Wiki Mod
Not in the near future. I like manual controls
In all realitly, I am not into programing, so it would be more work than it is worth. I would also need to add a temp sensor for engine bay temps. I want to help with start ups and aero but it is mostly for start up.
I might add a second switch so that I can turn one grate on/off. This would allow me to say keep one closed most of the time but on the rare warm day + freeway trip I can open both as I feel needed.
Old 09-22-2010, 03:36 PM   #109 (permalink)
...beats walking...
...the two important temperatures are (1) coolant and (2) intake air, not the underhood air itself, and since both of these can be monitored via ScanGauge, you should be able to monitor them to know when to open one- or both-vents.
Old 09-22-2010, 03:51 PM   #110 (permalink)
Wiki Mod
Yes but, I am still wanting to keep an eye on the under hood temps because of concern about cooking the electronics. My dad works with these things day in and out and thinks I still need some cooling.
Arduino controlled automatically actuated grill block Daox Aerodynamics 167 11-08-2016 11:23 AM
Piwoslaw's Peugeot 307sw modding thread Piwoslaw EcoModding Central 295 03-28-2016 03:25 PM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 04:36 PM
