Old 09-20-2010, 09:27 PM   #91 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I just swapped out the 1x board for a 2x4 chunk and the action is much smoother I think that the angle is better from the pivot to the grate connection.
Old 09-20-2010, 10:25 PM   #92 (permalink)
Wiki Mod
Made to a point that I want to try them out on the car:
Old 09-20-2010, 11:12 PM   #93 (permalink)
...beats walking...
...what brand/type actuator are you using; and, how much current does it draw when actuating?
Old 09-21-2010, 01:33 AM   #94 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
<snip>
Wow! That was pretty quick!! Looks like with the 2x4, the vanes of the grate open and close all the way?
Old 09-21-2010, 04:10 AM   #95 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Tools and Legos make a great mix
How about make it out of LEGOs?
Old 09-21-2010, 09:18 AM   #96 (permalink)
Wiki Mod
This is all I have for the actuator:
Universal Power Door Lock Actuator (2 Wires): eBay Motors (item 320579651247 end time Aug-29-10 08:33:14 PDT)
I have not measured the current when powered up.
@NachtRitter:
When I go to biuld something, once I have in my head a pic of what I want it goes fast.
It still only closes most of the way (say about 5% open). The stand off distance of a 2x4 plus 5 washers (under the pivot screw) puts the angle about right to pull/push the vanes up/down and in and out. They move up/ down by .75" and in.out by .4". Before all I was doing was the up/down movement. This holds the rod up and away from the grate making a slight angel which helps push in and out.
@Piwoslaw:
I thought of that, too bad it will not work. The Legos do not have the positive connection ability needed for automotive work, they would just wiggle apart.
Old 09-21-2010, 11:56 AM   #97 (permalink)
Wiki Mod
Test run not so good:
With the grates flipped so that the air would tend to push them open I ran into some issues.
1. the AC line to its radiator hits the left vanes as they try to open.
2. the distance between the vanes and radiator is very short, aka very little air dispersion over the whole radiator.
What this means, I need to make a way to turn the grates around (like I had them in my first try). This might need a redesign of the actuator location/ mechanism.
Old 09-21-2010, 01:22 PM   #98 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Weather Spotter -
@Piwoslaw:
That's what epoxy is for, . But use crummier Legos wherever possible.
CarloSW2
American Solar Energy Society
Old 09-21-2010, 01:49 PM   #99 (permalink)
Wiki Mod
I will not wreck my legos by epoxying them!
besides the pivot arm length needed is longer than I have room for (twice as long).
Old 09-21-2010, 02:01 PM   #100 (permalink)
aero guerrilla
Piwoslaw's Avatar
My hero...
Arduino controlled automatically actuated grill block Daox Aerodynamics 167 11-08-2016 11:23 AM
Piwoslaw's Peugeot 307sw modding thread Piwoslaw EcoModding Central 295 03-28-2016 03:25 PM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 04:36 PM
