05-03-2022, 10:26 PM
#231 (permalink)
I didn't know it had legs
Put the panel where it isn't?
Automatic jacks would lower but you don't want that at speed. If the car lowers the suspension goes up. Maybe I need a picture.
The window garnish can't hurt, could be better if it was continuous to the door lip.
05-05-2022, 10:27 AM
#232 (permalink)
guess
Originally Posted by Phase
any guesses you guys could make without actual testing? they dont look too detrimental
From old-school fluid dynamics, you'd expect flow separation, the 'thickness' of the void created, and perhaps, reattachment, 6- thicknesses downstream of the local horizontal point of separation.
An attached bubble of separated flow would travel along with vehicle.
You can see this in my 1st video for Spirit of EcoModder.
This turbulence has implications for downstream flow attachment, as you've now mutilated the onset flow, in subsonic flow, which influences pressure over the entire vehicle.
I'm not comfortable 'guessing', with respect to any delta-CdA.
05-05-2022, 10:29 AM
#233 (permalink)
lower
anyone know if the ioniq rear suspension legs lower at higher speeds? i dont want to put an under body panel at the rear and then the legs go down and hit it
I'm no IONIQ authority. If the car has 'active suspension', it hasn't been reported.
05-05-2022, 06:05 PM
#234 (permalink)
any benefits of side skirts like this once i finish and install my rear wheel covers?
sorry i havent been able to do any testing or installation, its been the rainiest april in the HISTORY of portland, and now so far its being projected to be one of the rainiest mays in decades
05-05-2022, 06:21 PM
#235 (permalink)
Is that two pictures of one thing or two things? Different models for the 2-door and 4-door?
In any case the exemplar is Aerocivic -- two parallel walls. The constraint is the breakover angle.
A possible solution would be solid spats at the front and rear with a tension cable at the bottom of a [semi-]flexible skit.
05-06-2022, 02:45 PM
#236 (permalink)
I think it’s the same skirt just on different cars. It slightly lowers it but it looks like the angle sticking out keeps some side air from going under near the body, and the rear little thing at the end of the skirt looks like it would direct air up only the rear wheel skirt when I make it
The Following User Says Thank You to Phase For This Useful Post:
05-06-2022, 03:25 PM
#237 (permalink)
The black winglet appears to be a vestigial air curtain. Maybe that's enough?
05-06-2022, 07:49 PM
#238 (permalink)
what's interesting is the toyota prius prime and the new corolla hybrid have some type of side skirt built in, while the ioniq hybrid blue is just straight down and flat
also random oddity, my gfs corolla hybrid returned 64mpg average on a highway trip we did going 70 plus mph. i do the same route all the time, and my ioniq only returns in the low to mid 50s in that stretch
this has happened a lot on highway trips. her corolla hybrid seems to get better mpg than my ioniq, even though the epa says my ioniq gets higher mpg, and has a lower cd. so i have no idea what's going on...
05-08-2022, 11:51 PM
#239 (permalink)
found this old pic when browsing old camping photos. no idea if this helps give an idea about air flow for the car. interesting at the rear...
05-09-2022, 10:18 AM
#240 (permalink)
'skirts'
I'd direct your attention towards Volkswagen's 'solution' to wheel drag.
In the 'archives' there's an underbody image you should see.
https://www.volkswagen-newsroom.com/en/xl1-3588
