03-28-2020, 02:01 PM
#391 (permalink)
Looking into a sprayer bidet now. I just finished replacing literally every piece of plumbing in my house, and have all of the parts needed to install a hot water line adjacent to the cold line for the toilet. I could probably have it up and running in half an hour.
I'll definitely need a hot water line. Vermont's tap water is frigid even in summer - I believe I've measured around 38-40F (~3.5C).
03-28-2020, 02:07 PM
#392 (permalink)
In my case adding a T into the hot water line would be trivial. But I use tissue paper to substitute for Kleenex.
Looking for an upside? Lionel Nation: How the End of the Federal Reserve Might Finally Happen Thanks to President Trump
...and whatever you do is we always say [remember] right arm, lock and load, power to the people and comment as you see fit
03-28-2020, 02:10 PM
#393 (permalink)
Rat Racer
Originally Posted by TexasCotton
The world is reaping the world wind of the backwards and unhygienic behavior Wuhan China ...
Nobody from Wuhan sneezed in Milan, touched a doorknob in NYC or shared a drink at Mardi Gras.
I'd look for one that had a heating element. How long do you need to run your water before hot comes out?
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
03-28-2020, 03:19 PM
#394 (permalink)
Running the sink, probably 60 seconds, it's an extremely low-flow faucet. It's perhaps only 15ft from the hot water tank. Though, an additional outlet wouldn't be difficult either, just a bit more expensive.
I'm not terribly concerned about "wasting" the water as it's from a well in the front of the house, which seems basically endless.
03-28-2020, 04:38 PM
#395 (permalink)
Rat Racer
I've got a well, too. "Wasting" water is really just moving it from the back yard to the front yard. I was thinking "all set for the water now" and getting a cold blast or waiting 60 seconds...
03-28-2020, 04:48 PM
#396 (permalink)
Divert it to the flushing reservoir.
Ps, most taps in finland have a thermostat.
So your 2 controls are flow and temperature.
03-28-2020, 05:03 PM
#397 (permalink)
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab 90 day: 20.98 mpg (US)
There is a plethora of toilet seat-based doodads that squirt water at your butt these days. No need to buy a lot of porcelain.
03-28-2020, 06:24 PM
#398 (permalink)
AKA - Jason
On my travels I've encountered the basic basin bidet and the wands. The basins work great in my opinion. Wet, scrub, rinse, dry. The soap and towel are on holders and easy to reach and all the water stays in the basin. I haven't had the same luck with the wands. I always end up with water all over the seat.
The fancy Toto Japanese toilets work well too but I don't want a toilet that says hello and the blow dryers take too long. I also don't really like the idea of blowing air OUT of the toilet bowl.
The Following User Says Thank You to JSH For This Useful Post:
03-28-2020, 07:17 PM
#399 (permalink)
Yikes! Maybe a subwoofer vibrating seat to shake the water off? A butt trumpet if you will?
03-28-2020, 09:54 PM
#400 (permalink)
[QUOTE=Fat Charlie;620206]Nobody from Wuhan sneezed in Milan, touched a doorknob in NYC or shared a drink at Mardi Gras.[QUOTE=
FYI
I have stated this before DO NOT para phrase my posts or statements!!
If you are slow a wit and are unable to justify the veracity of your own posts..
China Nationals go everywhere just like other world citizens you clown
