Old 12-11-2009, 06:29 PM   #2731 (permalink)
PaulH
MPaulHolmes's Avatar
Yikes! The new software has over-rev protection. That might come in handy. I can walk you through the the installation process if you want to try it.
kits and boards
Old 12-12-2009, 07:16 AM   #2732 (permalink)
jackbauer's Avatar
I'll second the packing! Took me 10 minutes with a box cutter to get my parts What about subing an igbt with the same package as the fets?
Old 12-12-2009, 01:26 PM   #2733 (permalink)
PaulH
Like a TO-247 IGBT? 10 of them? Or a big igbt module instead of the mosfets?
kits and boards
Old 12-12-2009, 01:33 PM   #2734 (permalink)
jackbauer's Avatar
yeah TO-247. Just bought a few on ebay for my charger project:
IGBT SGL50N60 600V 80A 250W short circuit rated (x4) on eBay (end time 15-Dec-09 00:44:35 GMT)
80A 600V. Just an idea as i think you mentioned the fets were on backorder.
Old 12-12-2009, 01:40 PM   #2735 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
The IGBTs don't parallel so well IIRC, they allow more amps as they heat up so the hottest one gets hotter and eventually need their magic smoke replaced. Mosfets do the opposite and are better suited for paralleling, so brick IGBTs for EVs it sounds like.
Edit, it was discussed about 2300 posts back
Old 12-12-2009, 01:43 PM   #2736 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
The seller of this merchandise is about an hour drive from my house.... My very first neighborhood
Old 12-12-2009, 01:49 PM   #2737 (permalink)
jackbauer's Avatar
My mistake. Just a thought.
Old 12-12-2009, 02:36 PM   #2738 (permalink)
Some IGBTs can be directly paralleled and some cannot. Check the datasheet. In general, Non-Punch Through (NPT) can be directly paralleled and Punch Through (PT) cannot.
In either case, it might be possible to use a bundle of wires instead of one large one so the wire resistances would tend to equalize the currents. Note that diodes generally cannot be directly paralleled, so it's a good idea to use a bundle even if you're using MOSFETs or IGBTs that can be directly paralleled.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 12-12-2009, 05:57 PM   #2739 (permalink)
Mark Weisheimer
You can use parallel IGBT devices if you have enough of them
and "match" them to each other.
The best way to use them is to test them for conductance and match
them as close as you can.
Say you have a box of 40 of the same type of IGBT device
and your design is going to use 12 of these devices.
To make these matcing measurements you will need a meter
that will read millivolts DC and
you would need 2 regulated bench supplies. (or, batteries and good regulators) One that will supply 15vdc at low current to drive the gate
and the second that will regulate current at 1 amp at whatever voltage develops across the drain and source. so a pair of 0-30VDC 0-1amp bench supplies would do nicely.
You would pick the 12 devices that fall within the smallest range using the following process that Nate at DIYElectriCar explained:
"What you want is the IGBT to act as close to its neighbor as possible.
Make sure the IGBT tests are all at the same temperature.
Test each IGBT individually but you should test them all on the same pad/heatsink.
Put 15V on the gate and 1 amp across the emitter and collector.
Measure the mV drop across each emitter to collector. Write it on the device.
Start each IGBT at the same temperature and monitor the temperature
rise over a set amount of time. What you want is consistency in voltage drop and temperature rise.
The final design should mount them on a common heat sink to help keep them thermally equal.
This is the basic way to test, you can vary the parameters but be consistent on all units."
Modules can be "matched" the same way, but should probably be tested using a higher current and a larger heatsink.
So, you can use what you have or can obtain at bargain prices.
There are plenty of EV's running around with parallel IGBT's in the controllers.
Mark
Last edited by Weisheimer; 12-13-2009 at 11:13 AM.. Reason: Correcting E/C for IGBT versus D/S for MOSFET
Old 12-12-2009, 09:46 PM   #2740 (permalink)
The $500 Electric Car
vpoppv's Avatar
Sorry for my ignorance in these matters, and all of the 999,999 further stupid questions I will ask, but should I stick to the parts in the Wiki, or can I substitute some parts? For example, could I use these capacitors:
25pcs CDE 250V 680uF Snap-In 105c Capacitors New! - eBay (item 200400013547 end time Dec-28-09 16:17:27 PST)
instead of the P11641-ND that Digi-Key offers?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
