Old 03-13-2013, 03:43 AM   #6041 (permalink)
Hi, thanks to all.
Okay, I thought so, regarding the EMC. But who cares
Has anyone the original altium files for the 2C version?
Old 03-13-2013, 06:18 AM   #6042 (permalink)
Greg; you worried me as big radio fan; is your controller's enclosure made from metal or plastics? I remember Jeff (Tesseract) saying that first thing to reduce EMC emission is to close power components in shielded box without any larger openings.
Old 03-13-2013, 11:20 AM   #6043 (permalink)
The end panels of my controller are plastic where the bus bars stick out, rest of the housing is metal.
Old 03-13-2013, 03:12 PM   #6044 (permalink)
jackbauer's Avatar
Would it be possible to mode the code (here i go again!) to use the htfs 800-p lem current sensor? This sensor works on 1.125*Ip/Ipn as opposed to 0.625*Ip/Ipn from the hass 300s and can measure upto 1200A.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 03-13-2013, 03:16 PM   #6045 (permalink)
Hey!
The simplest way would be to use a voltage divider ( 2 resistors ), so you don't have to change the code. Anyway it would be better to change the code, but if that isn't possible, you can go that way.
Old 03-13-2013, 03:45 PM   #6046 (permalink)
PaulH
MPaulHolmes's Avatar
Sure! If you have the original code, I can change it. I might have the original, but I have no idea where it is. It would only be like 1 line of code different.
kits and boards
Old 03-14-2013, 05:04 PM   #6047 (permalink)
jackbauer's Avatar
Thanks Paul. As always you da man! I'll drop you a mail.
www.evbmw.com
Old 03-17-2013, 01:16 PM   #6048 (permalink)
jackbauer's Avatar
Happy St.Patrick's day everyone Instead of spending my day in the rain watching the local parade I decided to start in on building the new controller for the land yacht. Control board is done and tested and have hooked up the htfs 800-p lem current sensor. Need a name for this new build. Thinking of something like the azure-revolt as it will have some azure dynamics bits and open revolt brain
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
MPaulHolmes (03-18-2013)
Old 03-17-2013, 01:22 PM   #6049 (permalink)
Hey!
Sounds great so far, I want to see the performance of your E39 with this big controller.
Which FETs/IGBTs are you going to use? And do you want to cool it with water, or just air cooling?
I've also sent you a PM, but I think you haven't read it so far. I was asking about your emulation of the crankshaft sensor, I've never seen someone doing that, so I don't know why you do that? I only see everybody to throw the original motor ECU away, because it's not needed, even for A/C and so on?
Thanks
Old 03-17-2013, 05:42 PM   #6050 (permalink)
jackbauer's Avatar
I'll be using 3 or 4 CM600du-12f 600v 600a igbt modules and liquid cooling. The reason for retaining the ecu is that its an integral part of the can network in the car. With no ecu the dash doesnt work etc.
www.evbmw.com
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
