Old 08-19-2014, 12:47 AM   #6841 (permalink)
PLUGnGO
jedsmd's Avatar
Originally Posted by Astro View Post
My first guess would be a low supply voltage.
Is the supply voltage still around 5v when it is in the truck?
Maybe try using an independent supply voltage to test it when it is bolted in position.
Or try taking it off the firewall but still connected to vehicle supply to see if the mounting position is the cause.
The cable allows the throttle arm to move all the way to the physical stop?
Could the wiring changes to the controller still have a series resistor in the supply circuit or something like that that allows the supply to test as 5v unconnected but when connected to the pot box it doesn't deliver full 5v?
Okay did some experimenting
Being mounted to the firewall has nothing to do with it. bad guess
The 5V supply from the controller is fine it remains at 4.94V.
Drum roll ......
The controller is loading the signal line. If you disconnect the signal line from the controller the signal line rises to 4.8v at max throttle. Connect to the controller it can only rise to 3.85v.
I think they can only supply 2ma of current on the output, but the pull down resistor is sucking 1mA. Maybe the pulldown should be more like 47k instead of 4.7k.
yep, but I'm not sure it is a problem I need to fix as it all works fine with the program variables set for the voltage drop.
The Following 2 Users Say Thank You to jedsmd For This Useful Post:
MPaulHolmes (08-19-2014), thingstodo (08-19-2014)
Old 08-19-2014, 09:47 AM   #6842 (permalink)
Dreamer
With the signal wire loaded with 4.7k to ground the current flowing in the signal circuit is 0.008mA at zero throttle and 0.844mA at full throttle.
i didn't have a 47k resistor handy to test the effect of increasing this value, actually i was using a 4.7k SMD resistor held by alligator clips as all my through hole components have all hidden themselves somewhere in the study. Obviously in fear of these new SMD interlopers.
Old 08-19-2014, 10:39 AM   #6843 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Always there is a Radio Shack store with some spare parts on hand....and "if" the store clerk have an idea or knowledge of what U R looking for....
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 08-19-2014, 07:33 PM   #6844 (permalink)
PLUGnGO
jedsmd's Avatar
A new problem...
For monitoring battery charge I use an 'EV Display' from Cleanpowerauto
EV Display - CleanPowerAuto LLC
The display goes bonkers when the controller is making power. The display is stable when the controller is not making power, but the displayed numbers for remaining charge are now rubbish.
I think this started when I reinstalled the spread spectrum software for the hall effect throttle. I had been using the 8khz fixed frequency until recently and hadn't had any problems.
I had tested the spread spectrum earlier and had not noticed any problem with the gauge so that leaves me confused. Paul did you make any changes recently other than the settings for the hall effect throttle?
Unfortunately It is hard to go back to earlier software versions to test because of wiring changes to the controller.
Paul please set me up a version of the 8Khz fixed freq with the hall effect values so I can test it with the display.
Thanks
Jerald
The Following User Says Thank You to jedsmd For This Useful Post:
Old 08-19-2014, 08:47 PM   #6845 (permalink)
PaulH
MPaulHolmes's Avatar
I just love mysteries like this. I'll do that now... new software sent!
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
jedsmd (08-19-2014)
Old 08-19-2014, 09:58 PM   #6846 (permalink)
PLUGnGO
jedsmd's Avatar
Originally Posted by jedsmd View Post
A new problem...
I traded Emails with Dimitri of CleanPowerAuto. They have seen this type of EMI from newer controllers and they recommended a simple filter to add to their device:
I have ordered the parts from digikey and will implement.
Meantime I will try the fixed freq code Paul just sent to see if it makes a difference
Old 08-19-2014, 10:01 PM   #6847 (permalink)
PaulH
Do you have the isolated dc-dc feature? Or is the EV Display ground the same as the pack ground?
kits and boards
Old 08-19-2014, 10:46 PM   #6848 (permalink)
PLUGnGO
jedsmd's Avatar
The 12volt sending unit ground is connected to vehicle ground. The pack positive and negative are connected directly to the sending unit (and are isolated from vehicle ground). There are no dc-dc's outside of what may be internal to the gauge.
Which raises a related question. Does the ground for the throttle hall sensor need to be isolated from vehicle ground?
Old 08-19-2014, 11:08 PM   #6849 (permalink)
PaulH
The throttle sensor ground is the control board ground, which is a filtered version of the output ground of the isolated dc-dc that's bolted to the roof of the controller.
kits and boards
Old 08-19-2014, 11:43 PM   #6850 (permalink)
Dreamer
Sounds like the pack is being grounded to vehicle ground through the remote sending unit. In the PDF they say that "If you need galvanic isolation between pack negative and your 12V supply ground, then you must use optional isolated DC/DC converter as shown on the wiring diagram."
If you have a spare 12v battery of some sort to power the remote sender independently of the vehicle 12v system it would prove if the isolation or lack of is causing the issue.
Maybe also put a meter between the pot box ground wire and its casing to see if they are internally connected. I would have expected there to be no connection between the hall sensor and the casing but you never know till you check.
The Following 2 Users Say Thank You to Astro For This Useful Post:
jedsmd (08-20-2014), MPaulHolmes (08-19-2014)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
