Old 03-26-2017, 09:44 AM   #611 (permalink)
No smoke or wind tunnel, just lots of arrows.
Random TRANSPORTATION pictures - Page 1843 - Pelican Parts Technical BBS
The Following 3 Users Say Thank You to kach22i For This Useful Post:
aerohead (04-01-2017), BamZipPow (04-10-2017), freebeard (03-26-2017)
Old 03-26-2017, 03:30 PM   #612 (permalink)
This explicates areas that would be difficult to photograph. The blue shading is helpful too.
Old 04-01-2017, 12:20 PM   #613 (permalink)
curious
Originally Posted by gumby79 View Post
That ^^^is sexy...
I like the tail section of the green house how it blinds into the flat deck. Looks like the air wants to follow ... I'm curious if the rear would have lift or downforce[edit: without the wing]? Looks like downforce with that up turn at the end.
The tail is similar to the bottom configuration in the table below,with lowest drag,although the lowest lift is with the middle configuration.
Old 04-10-2017, 10:12 AM   #614 (permalink)
This might be some form of ground pressure wave, just thought it could be related to topic.
MORE random pics...... - Page 4192 - Pelican Parts Technical BBS
I think it is easy for us to imagine a teardrop shape as aerodynamic, however it gets tricky with the ground plane interaction. It's like the elephant in the room. We all know that it's there, we just don't talk about it as much as the other stuff which is more easily identifiable visually.
aerohead (04-15-2017)
Old 04-10-2017, 12:58 PM   #615 (permalink)
Compare C in aerohead's post to this (lower left).
http://jalopnik.com/the-real-story-behind-the-nazis-and-volkswagen-1733943186
Old 04-11-2017, 07:06 PM   #616 (permalink)
Same idea, but not an exact overlay by any measure.
Aerodynamics by George Kachadoorian | Photobucket
http://forums.pelicanparts.com/off-t...pics-4193.html
Old 04-15-2017, 12:59 PM   #617 (permalink)
pressure
If this is the Barrett 50-cal. sniper setup,this would be a vectored supersonic shock-wave/pressure-wave propagating from the muzzle brake,helping to stabilize the barrel for the next shot if necessary.
Not quite as dramatic as the M.O.A.B.,22,000-pounder's,but quite telling!
Old 04-17-2017, 09:16 AM   #618 (permalink)
I don't see any ear protection, but he could be using ear canal bud plugs.
Looks like his helmet was knocked off, adding to the dynamic of the moment.
I was thinking the pressure/sound wave was bouncing off is body to move forward, otherwise the wave would continue in the opposite direction of the projectile.
A slow motion gif or video would be much more telling than this still image.
https://forum.warthunder.com/index.p...s-and-physics/
Aerodynamics | BLOODHOUND SSC
BLOODHOUND SSC will be the first – and, probably for a long time, the only – land-based vehicle in history to travel for a sustained period of time well above the speed of sound. Hence one of the crucial aspects of the aerodynamics of the Car is unique, and that’s the supersonic nature of the air flow, and in particular the presence of shock waves and their interaction with the ground.
Figure 3: Flow patterns around the ‘side-by-side’ front wheel configuration
http://www.bloodhoundssc.com/project...r-chassis/nose
Video:
Anatomy of the Car - The Nose
Published on Jan 27, 2017
A brand new series of programmes that will take you through the inner workings of BLOODHOUND SSC - a 1000mph car aiming to break the World Land Speed Record!
Video claims that the rear wheel fairings see supersonic air before the nose cone does................other interesting things in the video as well.
Many interesting images pop up when using the Google image search phrase: "bloodhound ground pressure wave aerodynamics"
aerohead (04-22-2017)
Old 04-27-2017, 08:16 AM   #619 (permalink)
1937/38 Mercedes Streamliner, the 540K Stromlinier
Go to 37:00 in video to see wind tunnel and smoke.
The Following 2 Users Say Thank You to redneck For This Useful Post:
aerohead (04-29-2017), sendler (04-29-2017)
Old 04-28-2017, 09:28 PM   #620 (permalink)
Search phrase: Saab wind tunnel
https://www.pinterest.com/y0947/a0s-...912-1967-saab/
Video: Saab Touts Heritage, Leaves Out GM Era (Almost) Entirely
https://www.pinterest.com/steve3190/wind-tunnels/
What I was really looking for was how this rear spoiler below actually worked, or didn't.
This Saab 900 Turbo Aero Is A Piece Of Sweden’s Eden
https://petrolicious.com/articles/th...f-swedens-eden
...........the rare “Aero” label designates, among some other touches, a more aggressive aerodynamics package that included those bodacious 3-spoke wheels that are now synonymous with Saab’s styling. The kit was comprised of the aforementioned skirting and lowered air dams which were developed with the aid of wind tunnel technology, so the next time someone asks you how effective your blocky Swedish polygon is at pushing through the air, you can quote whichever made up drag coefficient you want—as long as you also mention “wind tunnel” no one will question you on its atmospheric slicing abilities.
I've seen the same rear spoiler on the convertible version as well if I recall correctly.
