Go Back   EcoModder Forum > Forum News & Feedback
LinkBack Thread Tools
Old 02-01-2014, 01:06 AM   #511 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The Civic is dead; long live the Civic.
Born in September 2004 in East Liberty, OH, as a 2005 model, the Civic lived a long and happy life after being delivered to a dealer in Puyallup, WA, most recently commuting between Champaign and Mattoon, IL where it averaged close to 50mpg. Death came swiftly, in the form of a 24' box truck with a distracted driver. The Civic is survived by a new 2013 Prius. Memorial donations may be made to ExxonMobil.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
UltArc (03-31-2014)
Old 02-01-2014, 10:26 AM   #512 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Sorry for you loss. Will donations to Costco suffice?
Old 02-01-2014, 10:35 AM   #513 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
The pump didn't cut off in time this morning. So, I spilled a lil on the floor for my homies that didn't make it through the war.
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 02-01-2014, 07:34 PM   #514 (permalink)
Joggernot's Avatar
I'm assuming no one get hurt??
Old 02-03-2014, 12:42 PM   #515 (permalink)
darcane's Avatar
OK..
1) It's kinda weird that your car was originally sold in my home town.
2) That sucks. 7th gen Civics were the first to get a 5-star crash rating. That's one feature you hope to never put to the test though.
3) Are you OK? How bad was it?
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 02-06-2014, 01:48 AM   #516 (permalink)
Moderator
Vman455's Avatar
I'm fine, thankfully; the trunk was pushed in and there was crumpling in the rear quarter panel/unibody structure, so I'm not too surprised it turned out to be a total loss.
I actually bought the car (used) at Harnish in Puyallup in 2010 while I was teaching at PLU. They got it from Honda of Fife; the claim documents showed the whole history of the car, and it was originally delivered at a Puyallup dealership. And, apparently, involved in a front-end collision before I acquired it.
I've marked it as retired in my garage, but I'll leave it up until the 90-day economy runs out.
Joggernot (02-06-2014)
Old 03-30-2014, 10:42 PM   #517 (permalink)
Cyborg ECU
New fill. 62.xx or so MPG. Late in this tank, I started using higher shift points, as high as 2700 in second, 2500 in third, and 2400 in 4th. I also extensively used DFCO throughout instead of engine off coasting and braking. DFCO was for engine cooling and power generation. I turned the alternator on only during DFCO. The result is the lowest reading on the charger (3.37 kwh ) that I have ever had for a tank. FE was about the same or slightly lower over the last several tanks. The higher shift points might have been the reason for the FE drop, or not. Can't tell.
mikeyjd (03-31-2014)
Old 03-31-2014, 03:02 PM   #518 (permalink)
darcane's Avatar
Wouldn't the DFCO be the culprit as well? Any time you are using it, your coasting time will go down significantly so I would think it would be far less efficient than using EOC.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 03-31-2014, 05:23 PM   #519 (permalink)
Cyborg ECU
Yes that would be true, if I were using it indiscriminately. But I only use it in situations where I will unavoidably encounter excess speed and thus end up braking. In those situations, i have switched from EOC and normal braking to DFCO. Lots of hills ending at traffic lights around here.
Old 04-15-2014, 03:29 PM   #520 (permalink)
darcane's Avatar
Damn.
Looks like I may have bad news to report with my Civic too.
Started getting some high coolant temp readings (205-215°F) so it was time to take off my lower grill block. Pulled it off.
The next day I was still getting the high readings. Popped the hood and coolant had spilled a little out of the reservoir. Let it cool down and the radiator is low.
I'm pretty sure that means it's headgasket time....
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
