Old 09-09-2013, 10:20 AM   #121 (permalink)
90 day: 51.82 mpg (US)
The quiet, fast automatic engine start when shifting into gear, tapping the accelerator or depleting the vacuum reserve is one of the things I miss most about the Insight.
Old 09-09-2013, 05:31 PM   #122 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
I love that too, but its rare that I don't key off before the auto stop kicks on. I need a FAS...
I bet the thing you miss the most is Lean Burn.
Update : Its a dilema... My FCD shows around 900 mile and 96.8 mpg but I know it is more around ~95 mpg. 0/20 bars on the gas gauge. I calculated that with a 10.5 gallon (US) tank and 95 mpg I will do 997 mi if I use it all... What to do? Burn gas to get a better score and do 1000 mi, or wait for summer 2014 to do a 1000 mi tank ...
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 09-09-2013, 05:39 PM   #123 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Get that 1k mile tank! I am rooting for you!
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
The Following User Says Thank You to UltArc For This Useful Post:
HyperMileQC (09-09-2013)
Old 09-09-2013, 06:31 PM   #124 (permalink)
I try to be helpful. I'm not an expert.
The Following 3 Users Say Thank You to sheepdog 44 For This Useful Post:
HyperMileQC (09-09-2013), mikeyjd (09-09-2013), UltArc (09-09-2013)
Old 09-09-2013, 09:08 PM   #125 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Do eet! Take a 1 gallon can with you so you can run it all the way to 1000 and not get stranded.
Old 09-09-2013, 09:19 PM   #126 (permalink)
Yep - I miss the magic of lean burn most of all. I can't believe you haven't wired up a FAS switch! Makes things so much easier.
Old 09-12-2013, 09:10 AM   #127 (permalink)
Gen-1 Insights
Gen-1 Insights
I'm not a pro in wiring unfortunately... I think about buying a FAS from M Dabrowski, what do you think of it? It even keeps the 12v charging during EOC.
A assist inhibit switch like you did is also something I want to do.
Old 09-12-2013, 03:04 PM   #128 (permalink)
Gen-1 Insights
Gen-1 Insights
Finished my Grid Charger completely this week. It is now closed and the fan does a pretty darn good job keeping the components cool. Some pictures :
Some custom labelling
Grid Charger Pannel (110v plug, fuseholder, on/off switch and LED indicator).
I drilled some holes to help the cooling around the power supplies.
The 144v Female Plug
And finally, I put some weatherstripping tape to prevent scratches or tear from the screws when using it in the car or working on it on the table.
Old 09-15-2013, 03:04 PM   #129 (permalink)
Gen-1 Insights
Gen-1 Insights
Did my 1000 mile tank! I filled up today and did 94.69 mpg (96.5 mpg on FCD)! 1004.3 miles to be precise. With 10.606 gallon (US) I added a 1 liter before leaving so I counted it in the fill-up, but I calculated that even if I didn't put it, I could still have done the 1000 mi but I would have run on the fumes XD.
I bought a HD camera to take better picture of my FCD :
Trip A (Tank) :
Trip B (Potenza RE92) :
Lmpg :
And the results from my MPG run :
From the fuel station to my house I did 148.5 mpg / 1.58 LHK! :
My car after the fill-up :
The Following 2 Users Say Thank You to HyperMileQC For This Useful Post:
sheepdog 44 (09-15-2013), UltArc (09-18-2013)
Old 09-18-2013, 08:17 PM   #130 (permalink)
Gen-1 Insights
Gen-1 Insights
Now that I have finished my 144v grid charger, I started building a 144v discharger XD. I followed the same idea than M Dabrowki and I will use a shop light. Some difference, it will be manually controlled via an on/off switch. there will be two 300w shop light plugged in serial. The discharger controll box will plug to the grid charger so the 12v fan can cool the pack during discharging and will plug to the harness in the car.
We have modified the harness to put the diode in the power supply instead. We didn't thought about a discharger in the first place so we put it in the harness, but you can't discharge if you have a diode in the harness.
1 gen, honda, ima, insight, mod
