Old 09-18-2013, 10:37 PM   #131 (permalink)
minispeed-Insight - '00 Honda Insight
90 day: 82.15 mpg (US)
MDX - '01 Acura MDX Touring
90 day: 22.29 mpg (US)
the wife's car - '13 Toyota Prius Plus
90 day: 45.99 mpg (US)
leaf-one - '15 Nissan Leaf SV
I never did get my grid charger assembled, despite having the parts for many months.
It sounds like your battery is in better shape (balanced) than the one I had though - so you're doing this for a bit more efficiency, or to be nice to the battery?
The parts are finally in a case, but it's not 100% yet. I ordered a volt meter to get a display on the outside of the case and still have to add the relays and diode.
Originally Posted by HyperMileQC View Post
I'm not a pro in wiring unfortunately... I think about buying a FAS from M Dabrowski, what do you think of it? It even keeps the 12v charging during EOC.
A assist inhibit switch like you did is also something I want to do.
I love the switch, it's so easy to use. The position is perfect to use it for EOC, as I reach my hand to the shifter I hit the switch then pop it in neutral and kill the engine. Then I simply keep my hand on the shifter, stretch out my finger as I put it into 5th and hit the switch to have regen/assist back on. I've also used it several times to turn off regen while climbing hills.
Once I get the grid charger working I will use it to make sure I'm getting into work and back home with a nearly empty battery but no forced regen. I'm at work for 10hrs and can plug in so I should be pretty full when I leave.
So far though I've only gotten one 100+MPG trip to work (more downhill) and one 98. I'm mostly highway and keep it at 58mph avg. On the way home it's late so I can go a little slower but I have to climb the Niagara escarpment right at the end of the drive.
This will be my third and best tank in a day or 2 at 800miles plus with 84.1 showing for the tank.
Old 09-18-2013, 10:57 PM   #132 (permalink)
Harness Fuse Holder
The plans I had showed the 1A slow burn coming off the 110v and the 144v using a 04773.15MXP, 3.15A 400Vdc. What fuse did you use on the 110v line?
Old 09-19-2013, 02:53 PM   #133 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
You are right, I wrote 1a slow blow but it is the 3.15a. The 1a slo-blo is on the 110v.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 09-19-2013, 06:18 PM   #134 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Right now I am at one fuel bar left, 661.3 uncorrected miles, and an Insight estimated 65.8 mpg. When I filled up the tank the last owner worked on, he had 40~ mpg estimated until I drove and brought it into the 60s, and if I remember correctly, it had <2 gallons left at four bars.
I am anxious to take it to zero bars, as the Mustang is on Empty, and 50 gallons past, and she has a gallon left. But the Insight is making me anxious. Any tips? lol
Edit:
I forgot to ask, what fuse did you pull to disable the power steering? I looked at the fuse schematics online a bit, and it wasn't clear. The only ESP thing I saw seemed to control many things, and may be too much.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 09-21-2013, 05:44 PM   #135 (permalink)
Gen-1 Insights
Gen-1 Insights
I pulled the 40a fuse #15 under the hood. This deactivate the electric power-steering but you have the EPS light in the cluster tho... I removed it because I didn't liked my cluster looking like a christmas three .
The Following User Says Thank You to HyperMileQC For This Useful Post:
UltArc (09-21-2013)
Old 09-21-2013, 08:19 PM   #136 (permalink)
Does it help at all? MPG, or handling? I know i can feel the load just from driving with the parking lights on.
I try to be helpful. I'm not an expert.
Old 09-21-2013, 09:46 PM   #137 (permalink)
Gen-1 Insights
Gen-1 Insights
It help the most with electrical load reduction, to preserve the 12v battery so it is less charged by the dc-dc converter. The handling is better and it is really not difficult to turn especially with overinflated tires.
Old 09-26-2013, 10:05 PM   #138 (permalink)
Gen-1 Insights
Gen-1 Insights
Will reinstall my rear wiper this week end. Slowly preparing the car for the cold season... Aka winter is coming.
Old 09-26-2013, 10:18 PM   #139 (permalink)
90 day: 51.82 mpg (US)
If there was an opposite of "Thanks" button to press, I would press it now...
Old 10-03-2013, 02:11 AM   #140 (permalink)
Gen-1 Insights
Gen-1 Insights
Last week I cycled my battery pack with my grid charger and a discharger. It appears it has done miracle! When I first charged my battery, the SOC took 3 days to go from 19/20 to 3/20. After the charge & discharge cycles the pack took 7 days to go from 19/20 to 4/20 bars. Next plan is to put a ON/OFF switch with two different ON terminal. This will be my IMA inhibit switch/Max regen switch.
Will start on friday, I'll try to take some pictures.
1 gen, honda, ima, insight, mod
