Old 12-22-2013, 10:26 PM   #181 (permalink)
Gray Jellybean - '00 Honda Insight
90 day: 62.76 mpg (US)
I have a little clutch issue in that it has started to develop a shudder. Only in first gear, and either higher revs or a good warmup will solve it, but the revs were never needed before. Any thoughts?
Old 12-29-2013, 11:59 AM   #182 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
I'm not a clutch pro, does you clutch slip? If its only in first gear maybe its not the clutch afterall. Can't help much. I never had this problem.
Update : I recently bought a new cabin air filter. I replaced my old air filter (motor) with a new one. My brother gift to me for christmas was a fire blanket . So I installed it and it really help . Its exactly the same as echo-francis one. The 125w heater is not installed yet.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 01-14-2014, 02:00 PM   #183 (permalink)
Gen-1 Insights
Gen-1 Insights
Little update : I will stop laughing thursday. Didn't stop since September . I'm at 72.8 mpg on the FCD so I will do around 70 mpg and around 730 mi on this tank.
Old 01-14-2014, 08:02 PM   #184 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Nice! I thought you had a kill switch, but checking your page, I don't see it.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 01-15-2014, 02:06 AM   #185 (permalink)
Gen-1 Insights
Gen-1 Insights
I will not do a killswitch. I'll always key on-off-on OEC.
Maybe if one day I have something like MIMA I'll consider a FAS system, but remember that when you kill the engine with the FAS system, you can't bump start to restart the engine.
What I would like to work around is a way to activate or deactivate the DC-DC converter functions with a switch. That way I could preserve my 144v juice and I could charge the IMA battery less often. On short trips, I could let the DC-DC functions off all the way and charge my 12v battery at home with my 2A charger.
Old 01-17-2014, 05:39 PM   #186 (permalink)
Gen-1 Insights
Gen-1 Insights
Just filled up yesterday... FCD is off by ~10%. I ran out of fuel just a traffic light before the gas station but I used heavy assist in third gear and I rolled to the pump on electricity only .
Did 65.27 mpg (US) / 3.6 LHK. FCD said 72.8 mpg. That is probably why I ran out of gas XD.
Old 01-17-2014, 09:24 PM   #187 (permalink)
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
Yeah I have usually seen 5-10% less than the fcd shows.
The Following User Says Thank You to Insight for life For This Useful Post:
HyperMileQC (01-22-2014)
Old 01-18-2014, 07:00 AM   #188 (permalink)
IamIan's Avatar
Only in Phase-I of FAS while it is actively cutting the fuel injectors.
In Phase-II all FAS is doing is holding the clutch signal to make the car think you still have the clutch pressed down ( even if you do not ).
I have FAS and I have bump started ... when I FASed down a hill ... and I've also used MIMA to use the IMA to restart ... If I hold in my FAS button I stay in Phase-I which means I can also use MIMA to drive the IMA --- effectively a MIMA-EV-Mode... once FAS is in Phase-II the engine will restart from the RPMs.
Sounds like you need the DC-DC keep alive... usually combined with FAS.
When the IMA Battery Voltage is present ... any time after the high voltage connector activates in the beginning ... The DC-DC default condition is on in alternator like mode ... the OEM system sends the DC-DC a signal to turn it off ... if you break that signal wire with a relay you fall back to the default condition of DC-DC being on.
Although the DC-DC enable doesn't have to be integrated with FAS as one unit ... that is a commonly used method.
If you haven't seen it yet ... A good write up on the step by step of doing FAS with the DC-DC enable is the one Highwatter did Link
The Following User Says Thank You to IamIan For This Useful Post:
Old 01-26-2014, 03:37 PM   #189 (permalink)
Gen-1 Insights
Gen-1 Insights
The "Phases" you are talking about is the switch held on (Phase-I) and the switch relased after engine cutoff (Phase-II) ? If this kill the engine like when you key EOC, then you could really bump start like I do. Not with the electric motor.
About the DC-DC...
If the signal is normal the DC-DC converter default condition is alternator like mode. Then if you cut that signal with a switch. The DC-DC converter will stop working in alternator like mode until you return to OEM signal, right?
Then what doesn't work? What I was thinking about is a way to decide if the DC-DC converter works in whatever condition it wants or is OFF. I was not talking about the DC-DC enable thing. Why would I want to charge my 12v battery even during OEC when what I want to do is make the DC-DC converter work less often. You could compare this idea to an "alternator ON/OFF switch" on conventional cars.
90% of my mileage is short trips. So I could let the DC-DC converter off all the way and charge my 12v battery at home without problem. I want to save the 144v juice for assist and also to charge less often.
Old 01-27-2014, 01:19 PM   #190 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Having owned an insight that doesn't charge the 12v battery I can tell you that it will cause problems, unless your trip is under 15 minutes.
The insight draws a good 20 amps even with a lot of stuff disconnected due to the wastefull dash lights and other goodies.
If you want to attempt I would recommend determining exactly where the juice goes, maybe shut off the dash lighting and get a larger, preferably 14v battery pack.
Good Luck
Ryan
1 gen, honda, ima, insight, mod
