Old 08-06-2020, 09:26 AM   #201 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Yes! I even got a ride in one a few times. I had a buddy in high school whose dad owned two LADA sedans like your Fiat ... and a 1964 Pontiac Parisienne (sort of a Canadian Catalina equivalent). My fuzzy memory tells me he might have even had a Niva 4x4 at one point.
Wow. From wikipedia:
"LadaCanada started importing in 1979. The first model was the Lada 2106, with a 1500 cc engine. Later, the Lada Niva, a 1.6L 4x4 Lada, did very well, with over 12,000 sold the first year. In the mid-1990s Lada were selling around 12,000 cars per year in Canada.[2] Lada disappeared from Canada after the 1998 model year"
For me, today, when/if I get time I'll continue running-down source of intermittent electrical failure causing "false" O2 and VSS DTC codes to light up every once in a while.
MetroMPG (08-14-2020)
Old 08-07-2020, 03:23 PM   #202 (permalink)
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
Smart EQ 453 Facelift.
-Continental ecocontact 6
-35mm lower
-New Android Multimedia System
-closed wheelcaps
=9,8kwh/100km
Old 08-07-2020, 10:07 PM   #203 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Got the trunk open on the Fiat. Then I pulled the cylinder and worked it back and forth to loosen it up. Put it back together, closed the trunk and couldn't get it open again. Had to pull the back seat and undo the latch to get it open. Then tried again while paying more attention to alignment and got it. Now it opens as soon as you turn the key. The trunk is pretty impressive for such a small car.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 08-08-2020, 09:01 PM   #204 (permalink)
Cyborg ECU
Originally Posted by Jack-Lee View Post
Smart EQ 453 Facelift. ...
Got pics of the facelift?
Originally Posted by M_a_t_t View Post
Got the trunk open on the Fiat. Then I pulled the cylinder and worked it back and forth to loosen it up. Put it back together, closed the trunk and couldn't get it open again. Had to pull the back seat and undo the latch to get it open. Then tried again while paying more attention to alignment and got it. Now it opens as soon as you turn the key. The trunk is pretty impressive for such a small car. ...
Well, your Fiat's trunk is superior to an 06 BMW 3 series, which in REALLY GOOD SHAPE still makes it stupid hard to open the trunk WITH THE MECHANICAL KEY whenever the battery dies.
Old 08-09-2020, 12:01 AM   #205 (permalink)
Cyborg ECU
Working on my electrical problem. The ECU harness connectors do not pin out as the FSM says and the wire color coding is not always correct. Nonetheless, my p0141 and p0135 O2 heater circuit codes appear to be caused by an open in the circuit control line from the ECU connector to the sensors.
Maybe finish the diagnosis on the VSS tomorrow.
deluxx (08-09-2020)
Old 08-09-2020, 06:19 PM   #206 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Had a few hours to spare, so I welded on my suburban narrowing/boat tail project until I ran out of shielding gas. I got most of the structural welds and many other welds on the drivers side done. I have to swap over to my spool gun and 100% argon tank for an aluminum project, so it will be a bit before I continue.
Old 08-10-2020, 11:24 AM   #207 (permalink)
Cyborg ECU
Great progress! Inspiring. Will make my own report at the end of the day. Hate wiring problems!
Old 08-10-2020, 08:36 PM   #208 (permalink)
aardvarcus's Avatar
With no shielding gas and other priorities, tore into the 1999 4Runner ("Griffin", V6, 5spd, 4x4) this evening for some preventative maintenance. Replaced all 6 plugs and all 3 plug wires. Dropped the skid plate, drained coolant, pulled radiator hoses. Loosened the three tensioners and pulled the three flat belts. Ran out of time and wanted to get new coolant so didn't get it back together today.
Old 08-11-2020, 04:26 PM   #209 (permalink)
90 day: 51.82 mpg (US)
First MPGiata mod of the year
https://ecomodder.com/forum/showthre...tml#post629402
Old 08-11-2020, 10:47 PM   #210 (permalink)
aardvarcus's Avatar
Got the new belts installed, the radiator hoses replaced, the rear heat lines blocked off, and coolant refilled. Need to finish deleting the (never used) rear heat. Put a manual inclinometer to guage ascent/descent slopes. Began working on a ram mount for my GPS.
Edit: Almost forgot, changed the turn signal stalk to gain fog light controls. Added fog light fuse and relay.
