Old 11-14-2011, 06:43 PM   #191 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
This is the screen track system...
ScreenTight...
I got mine at Home Depot in Wichita during my last run and it was pretty cheap...$10 fer both top and bottom. Hopefully the window screen will hold up to the flexing...
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 11-14-2011, 10:40 PM   #192 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I'm thinking about putting in some button snaps to hold the ends of the soft ducktail down to the aero cap. Not sure how long it will hold in the long run though. Might have to combine another gutter guard on top/bottom of the window screen. We'll see.
Old 11-15-2011, 03:27 PM   #193 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Put some Coroplast under the soft ducktail to absorb any spray through. Coated the screen pretty good and then put another layer of window screen on top of that. It's just started to rain so I'm not sure if it's gonna set or not. Guess I'll find out after I start driving...
I ended up stapling some Gorilla tape to the 2nd layer and then taping that down to the cab. I stapled the sides to the aero cap so hopefully the 2nd layer won't fly off...
As far as I can tell...there's no rain on the back window!
Old 11-18-2011, 06:17 PM   #194 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Rubber spray never set...
Pulled the top cap cover off of the Screen Tight base. Repositioned the window screen so it will fold over the front spline track and cover the remaining base...kinda like a comb-over. Only the front edge of the base is exposed fer the moment. Added in some button snaps so I can keep the rear edge of the soft ducktail from flapping in the airflow and be able to unsnap it to deploy the cab cover.
Got some bedliner spray and will see how well that sticks to the window screen. Guess I should try to clean the screen with some acetone or maybe use another piece.
Old 11-19-2011, 05:45 PM   #195 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Cleaned up the soft ducktail and put the "professional" undercoating spray on it instead. Dried much faster and set up pretty nicely.
Reshaped the aero cap in the rear section...pushed the middle up about 2 more inches. Installed the rear window in fer the upcoming road trip. Hopefully it will keep the moisture out if it rains.
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (11-21-2011), landsailor (12-22-2011)
Old 11-20-2011, 02:47 PM   #196 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Looks good!
BTW, do you have a link to anything on the belly pan?
Old 11-22-2011, 12:15 AM   #197 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Originally Posted by Sven7 View Post
Looks good!
Under belly pan... - Toyota Nation Forum : Toyota Car and Truck Forums
The Following User Says Thank You to BamZipPow For This Useful Post:
Sven7 (11-24-2011)
Old 11-24-2011, 06:26 AM   #198 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Soft ducktail held up really well. Only a little bit of water got past it when it rained going through Dallas...but at least I could see out the back without a lot of raindrops on the back window.
The duckatail does puff up as I was driving since the rubber coating cooled it in that position..kinda like what convertible tops do driving down the road. I was thinking of making a slide out version next...although it would take more engineering than I have at the moment. . Maybe the ducktail housing could be sort of a roof heat shield, too!
Old 12-19-2011, 08:57 PM   #199 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Pulled the hatch off the other day so I could work on the next version of the ducktail...it's gonna be a rigid sliding one. Figure I'd use some of my 20" wide aluminum flashing and secure that to the top of the cab roof so it makes a pocket. Gonna try some 4mm Coroplast as my slider as it should be able to fit in between the roof indentions the Xtra-cabs have (regular cabs don't have them). I figure it should be able to slide out about 10" to cover the gap pretty well while leaving enough in the pocket to support it. I'm gonna have to make some stops so it doesn't automatically come flying out when I'm driving down the road...
Had fun pulling up the VHB tape...
Got the sliding ducktail in place...
Currently using some Coroplast as the slider and some of aluminum flashing as the cover secured with Gorilla tape (temporary fer testing). Kinda stiff sliding it in/out. Might try a single sheet of aluminum flashing on a trial run...
Closed...
Open...
Gonna peruse craigslist fer a free washer/dryer/fridge fer the sheet metal...
aerohead (12-20-2011)
Old 12-21-2011, 10:39 PM   #200 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
Revamped the center spar by putting in a support beam so I could pull the back end down and git the center spar with a more approximate curve to it.
Here's what the back end looks like now...I still have to reshape the rear window fer my upcoming trip to Tampa, FL...
Slid in a section of aluminum flashing in place of the Coroplast ducktail...
Got some rain to test it with...you can tell I need to use an English wheel to reshape the back part of it...
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
