Old 12-23-2008, 02:09 PM   #821 (permalink)
PaulH
MPaulHolmes's Avatar
My practical top speed is about 38, and the lowest speed limit in my neighborhood is 35, so I think Ben is going to hold the record for some time. That's really funny to get a ticket in a 15. I'm always staring down that the ammeter too.
kits and boards
Old 12-23-2008, 02:09 PM   #822 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by MPaulHolmes View Post
You have to go 75 miles round trip in a limited range vehicle after all that trouble, just to drive something that will eliminate your oil usage. I'm no conspiracy theorist, but holy cow... The System is not set up to become free of fossil fuels.
"Look how few EV's there are on the road! See, they just aren't practical. Maybe when the battery technology is ready, or blah blah blah..."
It is NOT a level playing field. I'm mad!
Dude... ritalin. You get angry very quickly! LOL Just messin wit ya :P
Old 12-23-2008, 02:38 PM   #823 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Originally Posted by MazdaMatt View Post
Ben, that sucks... must have pissed you off. Are you now the record holder for speeding tickets in a 72V EV?
I had a seperate thread dedicated just to the ticket:
http://ecomodder.com/forum/showthrea...cket-5454.html
MPaul: You're right, the system is stacked against us. I just hope that I am paving the way for others. It's always harder being the first at anything!
(The guy at the DMV claims that I am the first to do this. I KNOW for a fact, that I am not! I pointed out the fact that many conversions use older cars, which are already exempt from Emissions Testing.)
I very well may be the first to have a gasoline to electric conversion, in a 1996 or later model, in this particular 7-county area in SE Wisconsin, since that guy has been working there. Yeah, might be the first of that!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 12-23-2008, 05:58 PM   #824 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Here's what an electric car with bald tires does in the snow!
SnowDrifting!
My YouTube Videos
Old 12-23-2008, 07:18 PM   #825 (permalink)
:O No e-brake stints? WTH.. FWD drifting is extremely fun at times.
Old 12-23-2008, 07:46 PM   #826 (permalink)
PaulH
That was awesome! I liked that futuristic cougar sound it was making too! I'm going to try that!
kits and boards
Old 12-26-2008, 02:24 PM   #827 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Court Date
I went to court today for the speeding ticket I got in the car.
Please see my speeding ticket thread...
My YouTube Videos
Old 12-28-2008, 11:40 AM   #828 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Belly pan and 12v charger
Yesterday, I did a little more work on the car.
I put the driver-side under-fender back on. This was good, because without it, snow shoots right into the door hinge and then the door doesn't open right.
I finally started recycling the political sign for work on the belly pan.
I cut it to rough size and then crawled under the car. The front of the recycled coroplast was pinned to the car's bumper cover with a couple of self-tapping screws and washers.
There really wasn't any good place to screw the back end of the coroplast, nor the sides, because that's where the wheels (which move up and down) are.
For the back of the coroplast, I zip-tied it to the conduit, which is suspended under the car carrying cables from the back to the front of the car. I also zip-tied the coroplast in the middle to the conduit.
Then, I cut the sides of the cororplast to make room for the suspension, and the wheels to be able to bounce up and down.
The while back, when we got the motor and transmission back in the car, a lot of other things were moved out of the way for the work. This included removing the charger for the 12V car battery.
I am using a 12V trickle charger I already had (and never really had a good use for before) It is wired directly to 12V battery in the front of the car.
A problem with this charger, is that it's a weird shape, and there is no hole or any other simple say to bolt it to the car.
The charger does have two slots or notches, it takes some sort of crazy bracket (which I DON'T have) to mount it.
What I did have was two L-brackets and a bolt. I bent both L-brackets into an S shape and ran a bolt between the two, so that they would squeeze the charger, with the flat ends poking into the charger.
The flat end of the larger L-bracket tucks under the battery, which is held down by a traditional battery bracket.
The two charger wires use the bolts on the top-posts of the battery to connect with ring connectors.
In the above photo, just a little below and to the left of the red wire nut, you can see a female extension cord end. The trickle charger plugs in here, and the wires run to the back of the car, and connect, along with the 72V battery charger, to the AC charging port.
In this way, both the 72V and 12V batteries charge up whenever the car is plugged in.
My YouTube Videos
Old 12-28-2008, 10:12 PM   #829 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
"Best Of" Photos
I just spent the last hour digging through the photos I have taken of the project over the past year.
I have assembled them into an album for easy viewing.
These photos are in chronological order and give a pretty good overview to the project.
If a picture is worth a thousand words, these photos should sum up my year of typing handily...
See the album here:
MobileMe Gallery
My YouTube Videos
Old 12-29-2008, 02:20 AM   #830 (permalink)
90 day: 51.82 mpg (US)
Reverse 180's are fun too. I did some in the ForkenSwift, but didn't video it. Ben's more on the ball that way.
Unfortunately (???) the FS has snow tires on it, so it doesn't drift & spin as well as it could. :-P
electric car, electro metro, geo, metro
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 12:08 PM
Daox's 1997 Paseo Build Thread Daox EcoModding Central 241 11-13-2013 12:23 AM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 05:31 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 02:23 PM
