Old 03-26-2020, 12:13 PM   #191 (permalink)
These are cheap and not very easily defeated.
https://www.ebay.com/itm/Heavy-Duty-...sAAOSwnFZXUk3T
I have several and l’m very pleased with them.
Old 03-26-2020, 12:16 PM   #192 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
City Slicker 2 - '17 Chevy Bolt Premier
90 day: 124.1 mpg (US)
I'm sure you can find a video of the Lockpicking Lawyer picking it one in less than a minute.
Similar to this:
Old 03-26-2020, 01:39 PM   #193 (permalink)
We have a latch on the barn doors and we have had a lock on it, but how do I close it when I am inside?
The Veteran is not going into a place that can only be secured from the outside.
I would have cat6 running from my router to another modem?
Old 03-26-2020, 01:53 PM   #194 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
So is it an office or a panic room?
If you don't feel that your presence is enough to secure something, you probably ought to be doing it somewhere else.
Transmission type Efficiency
Old 03-26-2020, 01:55 PM   #195 (permalink)
JSH
AKA - Jason
JSH's Avatar
You latch the door from the inside with one of these:
Or if you don't want to spend $5 the you use one of these:
Are you actually concerned about someone stealing “The Veteran” (I assume your computer?) while you are in the shed?
EDIT: You are talking about using a regular door and deadbolt. For reference - when my wife locked herself outside while I was away on business it took the locksmith 2 hours to arrive and about 20 seconds to pick the deadbolt.
Old 03-26-2020, 02:13 PM   #196 (permalink)
Rat Racer
It's a shed. I'd use my universal key.
Old 03-26-2020, 03:13 PM   #197 (permalink)
In the Army we relied heavily on our master key:
Old 03-26-2020, 03:13 PM   #198 (permalink)
Katie, bar the door
https://www.ebay.com/itm/Drop-Open-B...-/182113888101
The older I get, the better I was -- John Fogerty on Joe Rogan
Old 03-26-2020, 03:18 PM   #199 (permalink)
Rat Racer
A $100 lock on a $10 door that's installed in a $5 wall is kind of a waste.
My shed is secured with a carabiner, to keep the hasp shut. What's a lock going to do other than cost money and inconvenience?
Old 03-26-2020, 03:40 PM   #200 (permalink)
JSH
AKA - Jason
JSH's Avatar
The same can be said of a house. After the locksmith incident I thought about upgrading my locks. Then I looked at the window next to the door. Then I thought about how easy it would be to cut a new ‘door’ in my wall with a battery powered circular saw.
I do have a lock on my shed. I want someone to have to make at least a little bit of noise to steal my stuff.
