02-27-2023, 03:29 PM
#931 (permalink)
'superceded...plus...plus....................'
Allegedly.... there were shenanigans around the time the Julian calendar was superceded by the Gregorian. Plus there was an 'adjuctment to the Julian in 45BC[E]. Plus there is the posibility that a millenium was lost when i650 became 1650.
Well that certainly clears it up! ( reaching for XANAX )
When on walks down on the creek, discussions of time with the turtles, duck, Blue Heron, cow birds, hawk, owl, and bobcat always end with 'the look.'
02-27-2023, 04:27 PM
#932 (permalink)
They will be unaffected by our impending doom.
https://en.wikipedia.org › wiki › Year_2038_problem
Year 2038 problem - Wikipedia
Unix time has historically been encoded as a signed 32-bit integer, a data type composed of 32 binary digits (bits) which represent an integer value, with 'signed' meaning that the number is stored in Two's complement format. Thus, a signed 32-bit integer can only represent integer values from − (2 31) to 2 31 − 1 inclusive.
Maybe an increase in habitat if we don't future-proof Unix.
."If there's ever a scandal about me, please call it Elongate."" -- Elon Musk "
02-27-2023, 10:37 PM
#933 (permalink)
The mega drought was mostly hype and the main reason why there wasn't enough water for people is the state has barely expanded water infrastructure over the last 30 years while the states population has increased at least 25%.
02-28-2023, 08:02 AM
#934 (permalink)
This guy predicted the earthquake in Turkey the other day.
Then there’s this, published in usda.gov
https://pubag.nal.usda.gov/catalog/7302130
Solar system planetary alignment triggers tides and earthquakes
Author:
Salih Muhammad Awadh
Source:
Journal of coastal conservation 2021 v.25 no.2 pp. 30
ISSN:
1400-0350
Subject:
case studies, earthquakes, geophysics, kinetic energy, momentum, potential energy
Abstract:
This research hypothesizes that tidal and earthquakes are induced by solar system planet positions, as the planetary attraction act as a trigger force change the speed of the Earth rotation. The occurrence of a sea tide is only a consequence of a relative slowdown of the rotational/revolving speed of the Earth which urges the Earth’s plates to move. The research included analyzing earthquake data for the whole Earth over July, 2019 with a case study of the Arabian Plate (AP) seismicity included the Zagros Folded Belt (ZFB) and Zagros Thrust Zone (ZTZ) as a seismic active belt in the northern hemisphere. The rotational velocity of the Earth has been calculated for eight seismic events, and it turns out that the velocity was different for each case. A negative proportional was found between earthquake and the Earth rotational speed. During the configuration of the Jupiter and Saturn in a straight line with the Earth over July 2019, one thousand and thirty-seven of earthquakes occurred around the world were statistically analyzed having 2–6 magnitudes. Rotational/ revolving speed, angular momentum and rotational inertia kinetic energy; gravitational potential energy of the Earth at equator and at 45 degrees were computed to show how rotational speed triggering plates. Planets interact with each other influencing earthquakes via the gravitational stresses arising from the configuration of the solar system planets that cause a slowdown of the rotational/revolving speed of the Earth. This stimulates the Earth’s plate to move generating earthquake due to the activation of faults
The ancients were obsessed with the movement of the planets and stars.
This could get interesting...
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
02-28-2023, 09:44 AM
#935 (permalink)
Skeptical about things predicted after the event. If this was repeatable, then earthquakes would occur regularly, and AFAIK, they don't. Best I ever saw was a Caltech professor that could name zones for earthquakes, but only within a 5-20 year window and not any actual level of force. Way too many variables for even GPT to predict
02-28-2023, 11:20 AM
#936 (permalink)
To prediction when 7 and greater will occur is becoming a reality.
They tend to happen when the earth crosses the suns equator, during the 5.9 month solar flare uptick and upon magnetic connection between earth and Jupiter.
To predict where they use data that includes lack of large quakes for a given area and an increase in tiny earthquakes.
02-28-2023, 11:42 AM
#937 (permalink)
Three-body problem
03-01-2023, 09:58 AM
#938 (permalink)
And?
03-01-2023, 10:56 AM
#939 (permalink)
It's high-school physics, isn't it? From the link:
The three-body problem is a special case of the n-body problem. Unlike two-body problems, no general closed-form solution exists,[1] as the resulting dynamical system is chaotic for most initial conditions, and numerical methods are generally required.
Historically, the first specific three-body problem to receive extended study was the one involving the Moon, Earth, and the Sun.[2] In an extended modern sense, a three-body problem is any problem in classical mechanics or quantum mechanics that models the motion of three particles.
Add Jupiter and you have a four-body problem.
03-01-2023, 01:51 PM
#940 (permalink)
100 years ago it was thought to be impossible to predict hurricanes. Now we watch them develop from satellite images time lapsed together on our phones.
Prior to Apollo one tried to predict solar storms. There was never a reason to.
We know exactly when the earth will cross the suns equator, when earth will magnetically connect to Jupiter with in a few days and within a week of when the 5.9 month cycle starts, it usually starts with small gangs of sunspots popping up, sun spot groups can appear and start flaring within an hour, maybe minutes.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
