08-16-2021, 07:56 PM
#1101 (permalink)
A moon roof and a full skirt...
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
08-16-2021, 11:01 PM
#1102 (permalink)
Yeah, like that.
Piotrsko -- It's a proven concept: DDG?q=ruger+/+gatling+gun+conversion. And I've got an Ender-3. Where I need help is the powered ring mount/hubless bearing.
What do you think of the name? Kohl is German for cabbage, -de abstracts an adjective. So, in German is cabbage-head or cabbage-brain a reasonable interpretation?
It looks like the Photoshopping washed out the shark mouth behind the front wheel. Those are E&J headlights.
.tragectory: Line goes down and to the right.
08-17-2021, 09:38 AM
#1103 (permalink)
I always thought it would be KOHLKOPF, but they are so uptight about any kind of slur they get weird really fast and become quiet.
Ok so this gatling thing is basically a siamesed rifle with a cam system to fire it and with what looks like cutesy barrel cooling. Mabye 50 rounds each before the barrel warps.
I have a 10-22, 50 years old maybe. It wont belt feed without a huge machining effort, but one could modify the storage system tube a bit.
I would just print an ersatz one because in my hood, this will attract double plus ungood attention......
Does your split have a sunroof?
08-17-2021, 02:13 PM
#1104 (permalink)
Thanks. That translates but doesn't have the double entendre.
The alternative name would be Barely Lethal.
I wouldn't consider belt fed, and even swapping the drums would be awkward through that little hole. The corrugated barrels are for cooling.
Sadly no sunroof. It's a 1958 Canadian, but the build plate has been Baja'd away, so it's just a big window body with semaphore pockets.
08-17-2021, 04:08 PM
#1105 (permalink)
So cabbage hans? OKAY. Perhaps a triple entender? However I don't get it. Dont explain.
I went belts for that WW2 look, drums fit the reload system concept better on my ruger but I think they need a clearance stagger and only require a random hand to stick out of the access hole.
Make the rings out of rolled angle iron then you just need a drive and grease.
Dont care how the covers work, after a stick of 15 CCI mini mags the barrel got inaccurate for squirrel plinking.
08-17-2021, 04:15 PM
#1106 (permalink)
Make the rings out of angle metal then you just need a drive and grease.
Chevron-cut [3D printed] planetary gears act as a thrust bearing.
Herringbone gear
A herringbone gear, a specific type of double helical gear, is a special type of gear that is a side to side combination of two helical gears of opposite hands. From the top, each helical groove of this gear looks like the letter V, and many together form a herringbone pattern.Wikipedia
'Cold dead hands' isn't on everyone's mind, apparently.
08-17-2021, 04:22 PM
#1107 (permalink)
Hasn't been since OBama
08-17-2021, 04:47 PM
#1108 (permalink)
The four years of Pax Americana was nice.
08-18-2021, 01:37 AM
#1109 (permalink)
JR bought a VW Insect
08-18-2021, 03:31 AM
#1110 (permalink)
A 1303 on low-rider 13s? Betcha it didn't race which that single-carb engine.
It takes him an hour just to get it off the trailer so the first thing he does is go hooning with a gas can on a pole. Then he proceeds to win a trophy!
