08-26-2020, 07:28 PM
#941 (permalink)
It appears to have a Type III engine, but I suspect the transaxle has bee raised to keep the back low with those tall rear tires.
I don't remember how some lowered Beetles in Brazil don't get an extremely negative camber, but it often doesn't involve raising the powertrain. Not totally unheard of lowered cars with the powertrain entirely raised, so maybe it could be the case on this one.
08-26-2020, 08:01 PM
#942 (permalink)
It's popular in the high-end drag racing scene. In the 1950s, instead of raising the transaxle they'd put Type II portal axles on upside down. (Hint: the lubrication doesn't work)
The difference between science and screwin' around, is writing it down.
Adam Savage _________________
09-07-2020, 09:40 PM
#943 (permalink)
Chopstix should like this one.
The only OEM parts are the windshield wipers, but it can get 50mpg.
I like the NACA ducts for rear brake cooling. With a stock engine that could be enough to feed the engine plenum.
09-17-2020, 06:53 PM
#944 (permalink)
09-22-2020, 07:23 PM
#945 (permalink)
Primer is still paint!
The Following User Says Thank You to ChopStix For This Useful Post:
09-22-2020, 08:27 PM
#946 (permalink)
Clicking the bar doesn't make it bigger.
IIRC, not a sunroof opening. What it needs is a lift-off padded Carson top. Or a plexiglass bubble slump-molded over a regular roof.
09-28-2020, 04:02 PM
#947 (permalink)
09-30-2020, 02:18 AM
#948 (permalink)
09-30-2020, 04:16 AM
#949 (permalink)
Eco-ventor
Found this guy hiding out in the woods:
10-01-2020, 02:33 PM
#950 (permalink)
Disclaimer...
But...
I play one on the internet.
