12-20-2012, 12:37 PM
#61 (permalink)
Originally Posted by cRiPpLe_rOoStEr
Relying only on Diesel power, even a BMW 5-series can still provide a higher fuel-economy than a Prius. It's also not so usual for newer Diesel compacts (including the Opel Astra which had been offered in the American market in its previous generation as a Saturn) to get 70 highway MPG...
No it can't. That article was BS.
12-26-2012, 12:59 AM
#62 (permalink)
The advantages of modern Diesels over a Prius or any comparatively-sized hybrid are not BS.
About the BMW vs. Prius: I must confess I got quite impressed how such a barge was managed to keep more fuel-efficient than a compact...
12-28-2012, 04:15 AM
#63 (permalink)
EtOH
GM was involved in their development, alongside Australian company Orbital Engines. Anyway, considering Mazda's experience with the SkyActiv engines it could be a substantial advantage if Ford got benefitted from its remaining ties with Mazda to bring the first commercially-viable HCCI.
Mazda is doing well enough on their own after they split ways several years ago. Ford went with using smaller turbocharged versions of the Duratec, Ecoboost. Mazda went with more efficient N/A engines, Skyactiv.
-Allch Chcar
12-28-2012, 01:10 PM
#64 (permalink)
Originally Posted by some_other_dave
Power density is a very silly thing to compare. It really only matters when comparing engines of very similar displacement, the same engine cycle, and whether or not it is naturally aspirated. It greatly favors small displacement, high revving engines.
I can go buy a production car this afternoon that gets 400+ hp/L. It's absurdly low-tech and I don't want to commute in it though.
12-28-2012, 01:27 PM
#65 (permalink)
Originally Posted by serialk11r
Closed deck iron block? I'm not super well educated on this subject, what does the iron block do for it?
It's actually an open deck, not closed (see pics lin link below). But having an iron block allowed them to not need sleeves and to siamese the cylinder bores to make it smaller. As a PR stunt, Ford took one on an airplane as a carry-on luggage:
Ford Built An Engine So Small They Were Able To Send It Through Airport Security
Ford boasts that it is small enough to fit on a sheet of A4 paper. (I assume this means the profile of the block alone, when viewed from the top).
12-30-2012, 12:15 AM
#66 (permalink)
Mazda still has some technical cooperations with Ford. The current overseas version of the Ranger, for example, is also offered as a Mazda (BT-50) in some markets.
12-31-2012, 06:37 AM
#67 (permalink)
Yeah, theres absolutely no connection between the current crop of Mazda and Ford vehicles.
12-31-2012, 08:52 AM
#68 (permalink)
The 1l triple is coming to north America this summer in the Fiesta...as a 2014 model.
I'll be trading in my 2011 for one!!
12-31-2012, 12:22 PM
#69 (permalink)
Do you think your real world FE will improve enough to justify the trade in?
12-31-2012, 01:57 PM
#70 (permalink)
I think I would rent one to see how much the mileage improvement actually was in a real world scenario.
regards
Mech
