Old 09-27-2008, 12:45 AM   #721 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Thanks, Wyatt glad you like it. Had a lot of time in figuring out a good case setup. I took two 4x2x1 Shack project boxes, the first I cut for lcd. The second I drilled through the case and got longer #6 screws from Lowes. Buttons are from the Shack too.
Old 09-30-2008, 08:03 PM   #722 (permalink)
Ok, the much delayed soldering is finally done, and I have another question. I only have the power jack to solder together. Does anybody know whether the center post is positive or negative?
Old 09-30-2008, 08:05 PM   #723 (permalink)
ptsmith24's Avatar
El Camrino - '90 Toyota Camry LE
90 day: 32.47 mpg (US)
Center pin is positive
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Old 09-30-2008, 08:28 PM   #724 (permalink)
Thanks!
Old 10-01-2008, 03:39 PM   #725 (permalink)
The soldering is finally done, and I'm ready to copy the IDE to it. When I plugged in the usb cord, Windows saw it as new hardware and wanted to install drivers for it. I cancelled that, but I can't find it when I look for it in the computer. How should I be doing this? Thanks.
Also, do I delete the first 3 lines about only using arduino version 0011 or leave them in?
Old 10-01-2008, 04:48 PM   #726 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
cmags did a pretty good job summing everything up (for an iDuino). They should all be basically the same.
You can leave everything as it is, no need to delete the first lines, they are commented out so they don't really do anything.
Old 10-01-2008, 05:18 PM   #727 (permalink)
Aaahhh, soooo....... You can just call me "Grasshopper." I did read the whole thread. I guess I forgot that reply from page 3 by the time I got ready. Thanks. Now I just need to put in the correct vss and injector values, and I should be set.
Old 10-01-2008, 05:27 PM   #728 (permalink)
You can look at the wiki for an idea on values to use, but the MPGuino will more than likely take some adjusting.
Old 10-01-2008, 06:10 PM   #729 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Do make sure you use arduino version 0011, not the latest one 0012.
Old 10-01-2008, 06:53 PM   #730 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Pontiac Firefly 3dr
90 day: 40.08 mpg (US)
Originally Posted by dcb View Post
10/01/2008
I also added a #define usedefaults so that you can build the guino without a lcd if you intend to only use it with a laptop/cellphone.
Is that what these are for? Which of these do I need to set? Just VSS, and uS/G?
#define contrastIdx 0 //do contrast first to get display dialed in
#define vssPulsesPerMileIdx 1
#define microSecondsPerGallonIdx 2
#define injPulsesPer2Revolutions 3
#define currentTripResetTimeoutUSIdx 4
#define tankSizeIdx 5
#define injectorSettleTimeIdx 6
#define weightIdx 7
#define scratchpadIdx 8
#define vsspause 9
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 10:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 06:23 PM
