Old 10-21-2014, 03:26 PM   #21 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Same slight fuel usage reported on my 2009 Fit.
I contacted Scangauge about it, suggesting a simple "if rpm = 0, gph = 0, else ....." code change. They replied that it's not a big error so no plan to fix it. This was about a year ago. I hope you have more leverage with them.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
MetroMPG (10-22-2014)
Old 10-22-2014, 11:28 AM   #22 (permalink)
90 day: 51.82 mpg (US)
I may not be good for much, but...
I'll have our engineer take a look and see if we can make any changes to help with this. Without causing any other issues of course.
I also provided a list of affected vehicles from this thread, and offered to be a guinea pig/tester if needed. (I suggested others here might be willing as well.)
2006 Toyota Corolla
1999 Saturn SW2
2003 Toyota Matrix
2001 Toyota Avalon
2005 Scion xA
2009 Pontiac Vibe
2002 Toyota Camry
2013 Subaru WRX STi
2007 Honda Civic
2009 Honda Fit
Old 10-22-2014, 03:18 PM   #23 (permalink)
Also...
This reveals a lack of understanding of the customer.
(Or at least one of their customer profiles.)
Old 10-22-2014, 10:01 PM   #24 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
'99 civic vs eoFc
After a trip using eoFc, a fillup consisted of significantly more gas than expected, the only time this has happened. The pump was tested and reported to be accurate.
I suspected that the car was using gas based on RPMs when the ignition was off, and have not used eoFc since that time. However, my use of eoNc has been accurate and has been verified at the pump.
Old 10-24-2014, 08:52 PM   #25 (permalink)
A fix is in the works... and in the mail
Originally Posted by Linear Logic
We've got a preliminary version for you to try out.
Good news: an updated Scangauge is on its way for me to test in the Civic.
jedi_sol (10-27-2014)
Old 10-24-2014, 11:24 PM   #26 (permalink)
...beats walking...
*IF* the updated software (revision) is successful, will LINEAR LOGIC let the rest of us send in our units for upgrade (at a reasonable cost)?
Old 10-25-2014, 07:44 AM   #27 (permalink)
In the past, I think the charge was $15?
Old 10-28-2014, 03:33 PM   #28 (permalink)
fixed
I'm not sure what the charge is for flashing the latest version. I'll ask.
But it appears to be fixed!
Before (my ScanGauge):
Above, that's my ScanGauge. The car is moving and the engine's off (should have switched to MPH from VLT).
After (test ScanGauge from Linear Logic):
ID:	16214   Click image for larger version
ID:	16215   Click image for larger version
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
NeilBlanchard (10-28-2014), OG VX (12-15-2014), PaleMelanesian (10-29-2014)
Old 10-28-2014, 04:28 PM   #29 (permalink)
So, can we send in our units, and get this? Soon, I hope?
Old 10-28-2014, 04:49 PM   #30 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Is that 4.13EM as in EcoModder?
New User Here: 2006 Corolla LE 5 Spd ncc74656m Introductions 11 05-25-2008 05:32 AM
