Old 11-18-2014, 05:36 PM   #181 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by The donkey CRX View Post
OG, your lack of performance and MPG could be due to colder weather or wind and rain. Don't panic until you are able to do a commute in clear weather with temps around 50 degrees. Every time I get stuck in heavy rains and wind, I always think something must have gone wrong with the motor because of the lower performance.
I noticed the loss of power with my insight as well in cold weather. Even if I drive around for 20+ miles. I too thought something was wrong until yesterday when it was ~65 and the car ran awesome, was easily getting 60+ mpg where lately, when the temps are ~35-45 I struggle to get 52-57.
The Following 2 Users Say Thank You to Baltothewolf For This Useful Post:
elhigh (11-19-2014), OG VX (11-18-2014)
Old 11-18-2014, 06:22 PM   #182 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Thanks for the insights fellas. You two are as seasoned as they come, so I hope your exactly right and that nothing is wrong with the old girl. I just figured that since the air was colder, it would perform better. Could just be what's still left in me from watching the first Fast & Furious though...
I'm still going to check the plugs. 3rd gear, in particular, feels hesitate to kick in on the throttle. I put half a bottle of SeaFoam in this morning. Maybe their is a bit of krusties stuck in an injector?
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
Old 11-19-2014, 08:22 AM   #183 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
It is, just not in the way that you're aiming for. You've got to love performance with all its various definitions.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
ecoTex (11-24-2014)
Old 11-19-2014, 08:25 AM   #184 (permalink)
Furry Furfag
I was under the impression that more dense (cold) air only helps under high engine/high RPM situations due to the way dense air reacts with fuel? (more oxygen for bigger boom). Under Light engine load/low RPM ranges, couldn't it cause a problem with ignition by having too much air mixed in with the fuel? Maybe I'm not understanding the way it works, but that makes sense to me-shrugs-
Old 11-19-2014, 09:10 AM   #185 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Too right! Morning temps are in the 20s around here, the car performs like I'm driving through an inch of slush even though the roads are bone dry. When you don't have much power to start with, giving some up to environmental factors feels like something has gone badly wrong.
The Following User Says Thank You to elhigh For This Useful Post:
The donkey CRX (11-19-2014)
Old 11-19-2014, 09:47 AM   #186 (permalink)
Rat Racer
At 30 degrees, there's more air in a cubic foot than there is at 80 degrees. So if you're stomping on it, you're getting more air into the cylinders in cold weather than you are in hot weather. Great for geting up to speed quickly, not so great for getting up to an efficient operating temp quickly or otherwise doing things with less gas. That's why other performance crowds like CAIs while WAIs are popular here.
Old 11-19-2014, 09:48 AM   #187 (permalink)
JDM hypeR mileR
OG VX's Avatar
Man, thanks for all the insight on my thread fellas! My first winter really watching my mpg's with such scrutiny. I was like "what is going on here?!".
I do believe the fuel pump was about to go out, though, as performance is certainly much better after the swap.
Old 11-19-2014, 11:25 AM   #188 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
not for pre-OBDII cars. Atleast, it appears not...with this code. ha!
Have you tried the paperclip method to find the CEL code?
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 11-19-2014, 11:54 AM   #189 (permalink)
JDM hypeR mileR
OG VX's Avatar
I have, thanks. But, it won't pull a code for me
Old 11-19-2014, 04:34 PM   #190 (permalink)
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
Hey OG, Here is an example of what I was saying above. The last week it has been between 14 and 47 degrees with wind and rain (even a little snow). I was struggling to get between 66 to 70MPG on my commute in the white 94VX. Today it finally turned out clear and got up to 56 degrees. I got 81MPG on my trip home this afternoon.
The VX is supposed to have around 90 foot lbs of torque, but I think when we are in lean burn we are only getting maybe 60 or so. This means any type of "drag", be it wind, rain, or thick cold air has a huge negative impact on the car's performance.
The Following 2 Users Say Thank You to The donkey CRX For This Useful Post:
COcyclist (07-23-2015), OG VX (11-19-2014)
