Old 08-27-2012, 03:07 AM   #1 (permalink)
Permanent cyl deactivation
I'm sure it's been discussed here or something but, are there any downsides to simply flat out disabling a few cylinders on an engine other than maybe roughness or something? Like could I turn a V8 into a 4cyl by just putting metal shims or something to block the intake and exhaust, or possibly pulling the lifters out so the valves never activate, or both... Or even down to 2cyl, or taking a factory 4cyl down to 1cyl. For that matter what if a person removes entire con rods/pistons from an engine so there's no friction, maybe just replacing it with a slug of similar weight on the crank so it doesn't imbalance while spinning??
Why do normal 'variable displacement' systems have to deactivate the valve mechanically, why not just some kind of butterflies in the intake or something? (or/and the exhaust but I don't see how that would affect anything even left unblocked)
This is really open ended, i'm hoping someone whose researched/tried it more might be able to bring me up to speed. The use would not just be for automotive - going to 1/4 the cyl originally designed is so little displacement you'd rightfully ask why not just use a smaller engine - the answer is sometimes junkyard car engines are even cheaper than small engines in a given size, slowing down rpm only goes so far - 've been given engines if I wanted to take them, yet the only application I wanted to use them for - like a small generator of maybe 10hp sustained they would still be grossly oversized for running on all cylinders... such a strategy could actually combine with extended in place engine life postponing rebuild/replacement by switching which cylinder you were firing on too, putting the old piston/con rod back in for one of the other cylinders and moving the crank weight over to the one you wore out. Heck maybe it could be a way to still use engines otherwise damaged - like cracked or scored cylinder walls but you aren't using them all so just disable those so damaged. That's a good example of engines often available for free.
I eventually want to experiment with temporary deactivation too like the new systems do but before I bother with that I figure better to get a handle on how to permanently do it so see if there are alternatives to just mechanical valve actuation.
Old 08-27-2012, 10:23 AM   #2 (permalink)
90 day: 51.82 mpg (US)
FYI, have a look at this thread: http://ecomodder.com/forum/showthrea...lly-21753.html
stillsearching (08-30-2012)
Old 08-27-2012, 01:57 PM   #3 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by stillsearching View Post
....Why do normal 'variable displacement' systems have to deactivate the valve mechanically, why not just some kind of butterflies in the intake or something? (or/and the exhaust but I don't see how that would affect anything even left unblocked....
Hi,
If you are going to deactivate cylinders, then simply pull the rockers from that cylinder, and make sure you do this both the intake and exhaust.
Why the exhaust too?
Because, anytime you start moving air around, there is a local loss of energy. With the exhaust valve opening, there is more airflow through the exhaust port and back again when the piston moves back down.
With both valves left in the closed position, air is repeatedly compressed, but at least there is no airflow, and compressing the cylinder results in some energy back into the system when that piston drops to BDC again.
Jim.
Old 08-27-2012, 04:04 PM   #4 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I have thought of doing this before but never done it.
I am no engine engineer so help me with this, what if I killed the fuel injectors to 2 of the 4 cylinders and left the valves in place? Say start with all 4 on then kill switch off a pair (say 2&4 or 1&3 in firing order). What if any issues would this cause? I can see my dash with a row of master kill switches (think aircraft panel with nice lights under them to indicate on or off)
Old 08-27-2012, 07:18 PM   #5 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Been there done that. 2 cyl is not enough power for everyday driving.
Cutting just the injectors will put air onto the exhaust and the engine control will respond by richening the mixture or going to open loop.
- Tony
Old 08-27-2012, 09:10 PM   #6 (permalink)
Wiki Mod
is air in the exhaust a bad thing? can I spoof the ECU to keep it in the right fuel range?
Old 08-28-2012, 12:05 PM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Air in the exhaust, affecting the O2 sensor reading, is an important concern and is also beside the point.
For an engine for which the non-firing cylinders' valves are allowed to open and close as before, the above graph shows how much useful work is generated by each firing cylinder, which is represented by the white area inside the curve. This is after heat losses to the exhaust and to the coolant are considered. The graph also shows how much suction work is needed by all firing and non-firing cylinders. That's the gray area.
Note that the non-firing cylinders still require suction work.
In this hypothetical engine, the work produced by each firing cylinder now has to cover the suction work needed by two cylinders - one firing, and one non-firing. This is in addition to the work needed to overcome friction losses, drivetrain losses, aerodynamic losses, and to propel the vehicle down the road.
Now, in this graph, the non-firing cylinders also have their valves deactivated. Note that the non-firing cylinders do not require work in the sense that they did when just the fuel injectors were shut off. Now, the firing cylinders just have to provide suction work for themselves, in addition to the friction and drivetrain and aerodynamic losses, and to propel the vehicle down the road.
The Following User Says Thank You to t vago For This Useful Post:
Weather Spotter (08-28-2012)
Old 08-28-2012, 05:22 PM   #8 (permalink)
Wiki Mod
so all that comes down to, without closing the valves its not worth it, the pumping losses will negate most (all) of the gas savings.
Bummer!
Old 08-28-2012, 06:01 PM   #9 (permalink)
MPGuino Supporter
t vago's Avatar
More or less. And, using a butterfly valve on selected intake runners, in order to shut off those cylinders, would be even worse than merely shutting down the injectors for those cylinders. I started work on a similar project for my truck, shortly after joining this board, only to come to the realization that this butterfly valve idea would not work as intended.
Old 08-29-2012, 08:58 AM   #10 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
He is not taking into account the lower manifold vacuum due to the 2 active cylinders working harder to keep up, the engine would be at full throttle twice as long with half the cylinders. I would go as far to say that under load it would have half the manifold vacuum and thus half the pumping loss. Of course if the valves were deactivated then it would have half the vacuum and half the displacement for 1/4 the pumping loss of a full engine.
Bummer!
- Tony
