09-27-2012, 04:38 PM
#561 (permalink)
That looks so cool, I really like the QR code idea.
09-27-2012, 04:48 PM
#562 (permalink)
Cyborg ECU
Originally Posted by Sven7
Wow!
09-27-2012, 04:52 PM
#563 (permalink)
Note flow detachment aft of the hatch lid gap filler.
Ha! I did notice those dust bunnies before I saw your comment.
Even loaded up the full-size Flickr photo of it, to which I said to myself, "needs more ensmoothening."
09-28-2012, 12:23 AM
#564 (permalink)
What's the hole just aft of the gas filler flap?
09-28-2012, 04:11 AM
#565 (permalink)
I like that small stencil (the smallest one I think)
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
09-28-2012, 07:21 PM
#566 (permalink)
Some tuft testing today, but no drive along. That will come tomorrow.
Tuft Testing Again! by Tyler Linner, on Flickr
I have a question for those who have done low speed testing. The 30mph video shows that the tufts aren't really doing much... hanging down and such. Should I disregard this evidence and just go by a high speed test?
Sooper seekrit hatch latch handle bandle. Opens the hatch.
The Following 4 Users Say Thank You to Sven7 For This Useful Post:
09-28-2012, 08:07 PM
#567 (permalink)
Woohoo! Tuft testing videos! Short but tantalizing....
I think the tufts are doing pretty much what they "should" be doing, but dang, those tufts are looooong! And therfore kinda heavy.
The "25 mph is OK for tuft testing" rule apparently assumes short, light tufts. Never thought about that before!
So going a little faster would probably help clear things up a bit, just to make sure the air is overcoming gravity's pull on the wooly bits.
That said, I think you can still make some conclusions that will hold up in a higher speed test:
- Up front, it's normal to see downward flow on the sides of the car aft of the front wheel, since there's high pressure at the windshield and lots of flow coming down around the A-pillar.
- The "hanging" tufts on the rocker panel are probably in separated flow behind the front wheel. (or at least very turbulent flow)
- Looks like you've got attached flow on the top of the tail, right to the tip - congrats!
- Upper sides of the tail look decent too.
- Looks like separation on the bottom of the tail though, at least around that single row of tufts close to the end. (Put a couple more tuft rows further forward for tomorrow's video!)
09-28-2012, 08:14 PM
#568 (permalink)
(PS - you should put a link to your build thread in your vid descriptions. Lovers of tuft testing, UNITE!)
09-28-2012, 08:21 PM
#569 (permalink)
Wiki Mod
Tuft tests look good. Bottom looks a bit steep.
09-28-2012, 09:37 PM
#570 (permalink)
Ultimate Fail
When I did my tuft testing, I found that using 2 1/2" lengths of thin lightweight cotton string gave the best results.
I tested the string alongside actual yarn and found that the yard had a tendency to stick to itself and anything around it - including body gaps and such .
I also ( tried ) to stagger the tufts apart so that the airflow would be clean and not influenced by the tuft directly in front of it.
On areas such as the rear windshield that get lots of glare, I tried different colors to see which showed up best. Sometimes white just disappears . I think it might be best to experiment with this, or perhaps have one side dark and the other light color
I hope you find someone that can act as a chase vehicle so we can get some more time to see what is going on with the airflow.
Love the car ! Thanks for posting
