Old 04-26-2011, 01:59 AM   #11 (permalink)
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
They are vinyl rain gutter with the front cut off. I use the same thing for my air dam.
Old 04-26-2011, 03:55 AM   #12 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
Are those soffit vents that you are using?
no... they're louvers, the kind that's punched trough from a single metal sheet... they have a screw in each corner, but are mostely held in place with tape... not sure they do much or are in the right spot, but they just sit between the radiator and the engine block wich is where i imagine the most air would exit before the tray was on.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 04-26-2011, 11:28 AM   #13 (permalink)
EcoModding Dilatant
oops, th9ought you were asking about the side skirts.
Old 04-26-2011, 01:52 PM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I love the photos. Thanks. I need some advice. I removed my prototype spats because they were clearly a net negative. I did not ABA test them. I wonder if they were too large. Mine were 2.5 inches (the space from bumber to the ground being only about seven inches. Would that be too large? Not large enough? Is there a proportional rule I might follow?
Old 04-26-2011, 08:00 PM   #15 (permalink)
EcoModding Dilatant
You might be interested in this article where tire spats were evaluated for lift and drag on a Prius. Evidently drag reduction is very sensitive to size, placement, and angle. Make them too large and they can increase both.
Autospeed - Modifying Under Car Airlfow
The Following 4 Users Say Thank You to instarx For This Useful Post:
67-ls1 (12-16-2014), California98Civic (04-26-2011), ECONORAM (06-19-2015), Regenerit (05-17-2012)
Old 04-26-2011, 09:48 PM   #16 (permalink)
Cyborg ECU
Thanks for that link instarx. I think I saw it once before but had forgotten, and I realize now that I was doing something akin to position number 5 on their list--seems like the worst idea. I'll try again with some other designs.
Old 04-26-2011, 10:56 PM   #17 (permalink)
Cyborg ECU
I just installed a quick prototype of coroplast fitting these rough demensions and position from your link above:
#4
270mm x 25mm, covers lower suspension link and tire
Drag 0.277
Front lift 0.038
Rear lift 0.121
My car is significantly different than this prius, but it has some very general similarities. If it feels alright on the road, I'll ABA test it soon.
Old 04-26-2011, 11:19 PM   #18 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I put the factory spatzs on to the underbelly panel in the same location they were in.
the[ underbelly pan is lower than the factory belly pan because of the IMPUL body kit
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-27-2011, 03:23 PM   #19 (permalink)
EcoModding Dilatant
Originally Posted by mcrews View Post
mcrews - tell me you didn't crawl under that car balanced on the edge of those wooden blocks!
Old 04-27-2011, 11:42 PM   #20 (permalink)
mcrews's Avatar
wooden ramps held together w/3 inch wood screws
the IMPUL front bumper is too low to use regular ramps so I had to build some.
base is a 2X8 then 3 2X6 the other side was dead on.
But thanks for your concern!!!!
ECO MODS PERFORMED:
First: ScangaugeII
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 10:16 AM
Front Wheel Skirts; 1950 Nash Ambassador Rokeby Aerodynamics 18 04-06-2014 01:14 PM
Alternative to wheel spats and smooth wheel covers? ESmooth Aerodynamics 17 12-10-2013 09:26 AM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 10:55 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 05:50 AM
