Old 04-21-2009, 12:27 AM   #11 (permalink)
Ritmusic2k's Avatar
Carmen - '00 Saab 9-3 Viggen
90 day: 23.38 mpg (US)
Instant MPG---------------Boost (xgauge; manifold abs. pressure minus 1atm.)
Intake Air Temp (ºF)-----Engine Load
I just got my SGII today, so I'm sure I'll be playing around with settings for awhile yet...
Old 04-21-2009, 07:15 AM   #12 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Boost
Water temp
trip mpg
mpg
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-21-2009, 10:02 AM   #13 (permalink)
coasting in neutral
Super22LL's Avatar
Georgia - '03 Chevrolet S10 Extended Cab Stepside LS
Last 3: 26.99 mpg (US)
Beth - '07 Yamaha R6S
90 day: 50.74 mpg (US)
Instant MPG MPH
Water temp. Avg MPG
My scan gauge has has helped me take my truck from 26 mpg to 31 mpg. I have greatly adjusted my driving habits based on it's readings and seen the benefit. I am monitoring water temp as I have added a grill block. It's been said here before, this is the first mod you should make.
Old 04-21-2009, 10:15 AM   #14 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
31 mpg in the S10 - you're already beating your original goal, Super22LL. Congrats. Isn't the SG great?
Old 04-21-2009, 10:23 AM   #15 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Instant mpg
Trip mpg (same as "current" screen)
Water temp - grill blocking
VLT / LOD / GPH / whatever else
The first two give me all I really need for maximizing mileage. At first the others were useful, but just for the learning period. VLT in the winter with EOC and headlights.
Old 04-21-2009, 10:40 AM   #16 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
MPG......GPH
AVG......FWT/TPS/RPM/MPH/VLT
The lower right gets switched as needed. The others don't change.
Nissan Versa Aeromods
Old 04-21-2009, 03:19 PM   #17 (permalink)
coasting in neutral
Super22LL's Avatar
Smile
Yeah Metro, the scan gauge is great. I thought it would be hard to meet my goal but it's come along very fast. I guess I need to set another goal lol.
The scan gauge has taught me how to drive, and the proper route to take to and from work. I haven't had to haul anything on this tank, it's been strictly work commuting. I plan on filling up today or tomorrow, so I'll have my new up to date MPG in my sig.
If you don't have a Scan Gauge, you need to get one.
Old 05-25-2009, 02:58 PM   #18 (permalink)
C12 H23 burner
Jeece's Avatar
Jeece's Jetta - '99 Volkswagen Jetta GL TDI
90 day: 42.49 mpg (US)
I always monitor Instant and Trip MPG (well, L/100km).
The two others depends on how I feel, or if I want to pay close attention to something else. Usually they're: Boost, Air intake temp, Water temp, Load, Voltage...
Old 06-17-2009, 05:17 PM   #19 (permalink)
EcoModding Neophyte
I just got mine this week but right now I have:
AVG - - - - TPS
MPG - - - - fIA
I find the TPS helps me keep a steady throttle and the instant MPG helps me keep my foot out of it on takeoffs, I try to always stay above 10mpg instant.
Very preliminarily, my Escape seems less prone to kick out of OD up a hill when the IA is over ~105 dF, which would seem to say hot air gives it more power, can this be? I gotta play with it some more but maybe a WAI would be good for mine.
I just got the SGII a week ago, I have not messed with xgauge yet but plan to, I want to be able to check trans fluid temp and I think I want tank mpg instead of trip mpg on my gauge panel.
2005 Ford Escape 2.3L/Auto
Old 06-17-2009, 07:12 PM   #20 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
MPG - - LOD
GPH - - IGN
I think I'm going to replace GPH with OPENLP/CLSDLP and see how I like that.
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
ScanGauge is bad for MPGs Tango Charlie The Lounge 2 08-10-2008 12:29 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 01:09 PM
