Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 03-24-2015, 05:48 PM   #11 (permalink)
Keep the stem and flat bars if the length is right for your body. I use a pair bar end grips moved inboard each 5 inches from center as my aero position. My light and speedo still fit. A car or tractor alternator of 35 amps or less would work for a generator set up. A spare rim might work with a belt to get the right rpm range.
Old 03-24-2015, 06:41 PM   #12 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
I also managed to hit out 2x 30min sessions on the turbo trainer tonight.
Mildy pooped now!
In other news, according to ebay, I'm due to recieve the bike computer and brake blocks in the next day or so. Tyres are due Thursday.
Hopefully have first meaningful update at the weekend
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 03-25-2015, 03:13 PM   #13 (permalink)
Team m8
Woooop!
First of the parts have arrived
Tyres look decent- certainly are thinner with what feels to be rubber, as opposed to the plastic like old tyres.
Inner tubes have a different valve system to the one on the bike currently-so I'll need to decide whether to use them, or keep them as spare.
Bike computer booted up and tested-just gotta get the transponder fitted to the bike, and see how it goes.
May try to fit them tomorrow night once i've had my ride.
|http://thumbsnap.com/kmUfUadZ[/url]
Old 03-26-2015, 06:03 PM   #14 (permalink)
Team m8
So, started to install ebay trinkets!
First up was the bike computer- a new fangled wireless device!
Simple case of applying the magnet to a spoke on the rear wheel, and mounting the sensor/transponder.
On my ride(turbo trainer) this evening it gave an average speed of 11mph over 30mins-pretty much bang on my average speed on Strava.
Very pleased for less than £5!
|http://thumbsnap.com/ybORA7w
|http://thumbsnap.com/KlPN4TDt
|http://thumbsnap.com/LDNNzBve
Old 03-26-2015, 06:55 PM   #15 (permalink)
Team m8
Next up was to sort out the tyres.
I was moving from 26x 2.05 off road to 26x 1.95 road biased tyres.
the new tyres were purchased along with new tubes, but the new tubes have presta valves so my pump didnt fit.
I reinstalled the original tubes, then fought with the footpump. As soon as it was attached to the valve it started to allow air to escape-so inflating the tyres was less than fun.
I'll put some air in tomorrow or Saturday.
And, yes I know the bike is filthy!a wash will happen at somepoint.
Additionally it appears that the rear wheelbearing is ropey, and the front wheel has a wobble. New wheelset should be on the cards then..|Pistonheads - ThumbSnap - Simple Image Hosting & Photo Sharing
Old 03-27-2015, 03:10 PM   #16 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
If you want to keep your new tubes you can buy an adapter to bridge the gap between the Devil's Valve* (presta) to normal Schraeder. It's just a little brass cylinder you screw onto the end of the presta. Better than presta, worse than Schraeder, and available for about $0.50 from your LBS. It'll work with your pump, though!
*Also known as, "$&%# these stupid twisty valves!"
How do you like the new tires? Do they roll better?
Old 03-27-2015, 04:52 PM   #17 (permalink)
Team m8
Yep have found out about the valve adapters. Thanks for the info though!
Re the tyres i have no idea-i went to the pub this evening instead
With luck i should be able to test them tomorrow during the day and get a ba k to back average mph on the turbo trainer.
Will report back!
Old 03-27-2015, 06:32 PM   #18 (permalink)
Team m8
Next up were the brakes..
Application of new blocks, correctly aligned and accompanied by adjusted cables means that the levers now have resistance before they get to the handlebar grips
Having got this far yesterday, I elected to attend the pub tonight.
Trial run (either in the real world, or on turbo trainer) should occur tomorrow morning. |Pistonheads - ThumbSnap - Simple Image Hosting & Photo Sharing
Old 03-27-2015, 08:06 PM   #19 (permalink)
I like to pull the cables and grease 'em up good. They stay nice and slick far, far longer than cables lubed with oil.
Old 03-28-2015, 06:26 AM   #20 (permalink)
Team m8
I shall investamagate! A lack of grease precludes such work occurring today
