Old 10-28-2019, 09:16 AM   #91 (permalink)
Sounds like a great idea to me. I'm looking forward to seeing it finished up and hearing more results. Thanks for sharing!
Old 10-29-2019, 01:36 PM   #92 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by Natalya View Post
Something I am thinking about doing, going off a conversation I had with IamIan at Insight Fest 2019 and with him earlier in this thread, is installing a grid charger harness and then trying to drive while using assist as much as possible during the day, and use EOC instead of regen for hypermiling purposes. Then when I get home I could top it off with the grid charger.
Too fun.
I used my tired Insight pack in reverse: rarely used assist, but I used regen (when I had to) to feed the pack. I figure that regen was powering my 12v stuff at least.
aerohead (11-06-2019)
Old 10-29-2019, 06:37 PM   #93 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Something I am thinking about doing, going off a conversation I had with IamIan at Insight Fest 2019 and with him earlier in this thread, is installing a grid charger harness and then trying to drive while using assist as much as possible during the day, and use EOC instead of regen for hypermiling purposes. Then when I get home I could top it off with the grid charger. But I probably won't sort that out anytime soon.
Be sure to count the cost of electricity used, as the mpg numbers will be artificially high. What is the cost of electricity by you? If electricity is cheap, this may be a good way to offset the cost of the conversion.
Awesome stuff you're doing with the car.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
Old 10-29-2019, 10:46 PM   #94 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Too fun.
Yes, that's exactly what I had been doing for the last 2 years since I bought the car. Clutch switch turned on almost all the time, and then I have an Auto-Stop I would use for Engine-Off Coast. The IMA motor would restart the car, but I never otherwise used assist.
But the pack got worse and worse, and so recently I removed it so that at least I'd save some weight. The new LTO setup changes the game completely.
Electricity is cheap here, and at most I could expect to only put 1 or 2 kilowatt hours into it. But I haven't got this setup yet.
The Following User Says Thank You to Natalya For This Useful Post:
Old 11-06-2019, 04:17 PM   #95 (permalink)
belly
Okay so on my Silver G1 I put three aero panels under the back. One of them was really huge compared to the other two. I still have the measurements so I could duplicate it.
But I'm wondering what I should do for max FE? Ecky for example put big sheets that go under the whole body of the car.
A thought was I could use coroplast I have left over from the Black G2 to recreate the old G1 pan. Then, because it attaches easily, I could do some ABA testing. A testing regimen would be like I accelerate to 10 mph then throw it in neutral and see how far the car goes before stopping. But aero drag is most prevalant at higher speeds. I could try like getting to 40 then at a certain point on a road I could throw it in neutral and see how far it travels before hitting like 25. But then I'd need to be going down this road quite a few times with no traffic there. I'd also need a suitable road.
Anyone have any ideas how I can test?
We know from a number of published wind tunnel research projects,that any paneling will 'show.' Honda's already done the pick and shovel work,so anything we do is just small incremental improvement.
If you ever do a boat tail later,any upstream smoothing will help deliver the highest quality airflow to the rear.
The boat tail though,is the moneymaker.On the open road.
Natalya (12-22-2019)
Old 12-22-2019, 08:53 AM   #96 (permalink)
Engine-Off-Coast
Natalya's Avatar
It's been sorta cold here. Actually froze a couple nights ago. I've been getting bad MPG, but I have also been driving it like I stole it. I have to drive so much these days I hate it. But I still get over 60 MPG, so at least all the mods I've done are still helping me.
Today I hope to build a grid charger harness (finally) and do the 30% extra current hack for the IMA system.
The Following 3 Users Say Thank You to Natalya For This Useful Post:
Daox (12-22-2019), Ecky (12-22-2019), mpg_numbers_guy (12-22-2019)
Old 01-13-2020, 02:38 PM   #97 (permalink)
Engine-Off-Coast
Natalya's Avatar
Vredestein Quatrac 5 165/65 R14
I heard they weigh 1 pound less than the RE92. I'll be the guinea pig. I was on RE92s at 61 PSI, I just got these on here same pressure. Their sidewall max is 51 whereas RE92 is 44.
Ecky (01-13-2020)
Old 01-13-2020, 02:47 PM   #98 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The tread is a little narrower. Can confirm they're very light. I have 185's on mine.
Natalya (01-19-2020)
Old 02-01-2020, 01:09 AM   #99 (permalink)
Engine-Off-Coast
Natalya's Avatar
Okay I've had them for about 2½ weeks now. At 62 PSI they MIGHT have a small hit on MPG but the weather is incredibly variable recently so it's hard to tell is it the tires or is it the cold? Also, traffic has not been predictable.
They are barely quieter than RE92s at highway speed.
I have better traction, but I also have tire tread now. XD
LTO current hack is ruining my MPG.
Because the car goes vroom vroom now and you can actually accelerate.
So I waste energy doing that.
I've been trying the PHEV method of charging it most nights for a couple hours before I go to sleep. I've been writing some Arduino code to manage the charging automatically. I'll post when I get that finished and installed.
I divided my garage entry into a 2017 - 2019 entry and a new 2020 entry so the fuel log doesn't get too small to read.
Daox (02-01-2020)
Old 02-01-2020, 10:27 PM   #100 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Short trip but still impressive that if I had the time
I have 2xre92’s and 2x vredsteins low 30’s warm engine fresh refuel low speed ima removed
The Following User Says Thank You to rmay635703 For This Useful Post:
RedDevil (02-09-2020)
