Old 07-27-2020, 10:48 PM   #171 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Finally got enough things trimmed and clearanced, pulled the Suburban Drivers side cargo wall over 6" forming the first half of the boat tail. It was suprising how many different places wanted to bind up...
Old 07-28-2020, 09:26 AM   #172 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
6" is a good amount of taper on that long and large body. It's gonna look cool and perform well.
Old 07-28-2020, 02:03 PM   #173 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Yesterday, I bought another car. 1973 Fiat 124 Special. This one is auto and has A/C. Pretty solid overall. Nicer condition than the civic. If the engine spins (haven't tried yet) then I think I can get it to fire pretty easily. Here is a pic from the ad.
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 07-28-2020, 02:52 PM   #174 (permalink)
Cyborg ECU
That is great. Picture does not display though. A question for anyone: how much damage might I cause if I run a Honda engine from cold, at idle, for about 20 seconds, without any oil. I was in the middle of an oil change and got distracted. While it ran it had a hunting idle below normal--between maybe 1200 and 1700, but I remember seeing a moment of almost stable ~1400 RPMs maybe once maybe twice just before I realized the mistake and turned it off. THOUGHTS?
Old 07-28-2020, 03:26 PM   #175 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
Not good, but you didn’t drive it to the parts store for oil/filter...after draining the oil like one customer of mine did once. Probably ok, might be worth a quick compression test.
I changed the alternator on my Civic. A bit more of a bear to maneuver in and out than it should have been, but it’s all good now. It wasn’t charging over about 3300rpm, so I knew the day was coming when it would fail...and it did. The upshot is that I got an excuse to bang the rev limiter a couple of times to verify the fix and still got 32.x mpg when I got home. Sweet little revver that D16 engine, but fast it is not.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 07-28-2020, 03:44 PM   #176 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Probably fine. Usually enough oil film left to keep parts moving for a bit. Project farm did a video of engines with no oil. They lasted quite awhile (~20 mins).
1995 Mercury Tracer
The Following User Says Thank You to M_a_t_t For This Useful Post:
California98Civic (07-28-2020)
Old 07-29-2020, 02:52 AM   #177 (permalink)
GreenTDI's Avatar
GreenTDI - '11 Skoda Fabia Estate R3 1.2 CRTDI
Diesel
90 day: 65.02 mpg (US)
In addition to what Matt says, I think you might have been lucky it was just for 20 seconds. There will still be some oil left on the walls or in cracks, you are still a 'long' time away of burning it all. So it is not that the engine was completely dry.
See my thread: https://ecomodder.com/forum/showthre...mpg-38318.html
The Following User Says Thank You to GreenTDI For This Useful Post:
California98Civic (07-29-2020)
Old 07-29-2020, 11:55 AM   #178 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I pulled the valve cover off the Fiat. It doesn't look very great. I then put some compressed air in the cylinder that was on the compression stroke and nothing happened. Little to no hissing either. So the engine is stuck. Looks like it will be put on hold until I get farther on the civic and other projects. I will keep my eye out for some new (second hand) tires though so I can put it back on the ground and off the dollies. Once I get some practice replacing windshields I will pull this one off and re-seal it. The front is leaking so I threw a large tarp over the car for now.
1995 Mercury Tracer
Old 07-29-2020, 02:59 PM   #179 (permalink)
Cyborg ECU
I pulled the valve cover off the Fiat. It doesn't look very great. ...
I am gonna be way impressed if you save that valvetrain. And thanks for the reassurances on my somewhat botched oil change, guys. I sounds and drives the same today, so... after work I will do some more prep for my SMOG test.
Old 07-29-2020, 03:22 PM   #180 (permalink)
90 day: 51.82 mpg (US)
I had the same thought: it takes many minutes to destroy an engine without oil in the pan.
Third opinion: https://ecomodder.com/forum/showthre...red-38235.html
