02-27-2018, 07:37 PM
#51 (permalink)
What about this Peugeot 504 converted into a tricycle in Syria due to lower taxes? Unfortunately here in Brazil a trike would be liable to a higher DPVAT (insurance for accident victims, not material damage) since it's legally considered more related to a motorcycle...
But anyway, once I got too drunk that I started lurking about doing something similar using the bodyshell of a 2nd-generation S10 Blazer and some small tractor engine (most likely a 1.3L air-cooled inline-twin boat-anchor designed by Hatz and made under license by Agrale).
02-28-2018, 11:55 AM
#52 (permalink)
Is this considered a car on Brazil ?
02-28-2018, 01:09 PM
#53 (permalink)
As long as it's fitted with steering wheel it's legally a car in Brazil. But IIRC artesanal cars are exempt from the airbag and ABS brakes mandate.
02-28-2018, 01:18 PM
#54 (permalink)
Uhhnn...
What if... if the wheel it's not exactly a wheel ?
Sorry the few humor...
02-28-2018, 01:36 PM
#55 (permalink)
Then you'd definitely need to register it as a trike. And hope the Inmetro inspector agree to consider that as a handlebar with the tips slightly bent...
02-28-2018, 04:38 PM
#56 (permalink)
How many turn lock-to-lock?
.Necessity is the mother of invention, but simplicity is it's favorite aunt --Amish proverb
03-01-2018, 02:51 AM
#57 (permalink)
Most likely you wouldn't be allowed to do even a complete turn, in order to keep both hands in the "handlebar" all the time (unless it has a shift lever like a typical car instead of the pedal-shifter that you'd expect to find in a motorcycle).
03-01-2018, 05:32 AM
#58 (permalink)
Handlebars have a ratio of 1:1. If the wheel[s] turn 120° lock-to-lock, a single revolution of a wheel would be a ratio of 3:1.
Ditching the wheel on the Arcimoto shortened the wheelbase, an architectural advantage. Shifting is for people without a single-speed drivertrain.
03-01-2018, 06:56 AM
#59 (permalink)
Well...
https://youtu.be/V1WbvwQCTvU?t=440
Looked easy... And even looked cool.
Sorry my ignorance. I didn't get how a pedal and a gear tool can change steering wheel rotation in a car.
03-01-2018, 11:40 AM
#60 (permalink)
Something must've been lost in the translation, but anyway, while it's required to keep both hands on the handlebar all the time while riding an actual motorcycle, in a trike you would be allowed to use a regular shifter like in a car. When it comes to change the steering turn ratio, it's up to the steering gearbox. Have you already noticed that some cars often have less turns lock-to-lock when fitted with power steering, while the versions not fitted with this resource have more turns in order to make the steering at least feel lighter?
