Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 06-06-2012, 08:44 AM   #231 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Become a Doctor of Magnetics!
Join this group and check out the LINKS section to earn your Doctorate of Magnetic attraction.
Be the first on your block to know ALL about magnets?
Impress your friends.
Attract women by putting magnets in their pockets.....
diy_magnet_use : DIY-magnet use
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 06-06-2012, 03:04 PM   #232 (permalink)
Jet - '01 Volkswagen Jetta TDI GLS
This reminds me of in college when I was in a team of students trying to solve the problem of pumping fluids in zero gravity. We ended up adding different metals to the fluids in order to use magnetic force to control the flow of the fluids. Eventually the metal bits tore apart the pump though
Anyone have a 5 gallon tank of gasoline or diesel hanging around? Take a magnet preferably a very strong one, tie it to a string dip it in there and shake up the container. Let the container settle, remove the magnet and search for anything it picked up. If there is anything at all it could be plausible, if there is nothing repeat with gas from different stations. My guess would be the highest likely-hood of finding something like this would be in diesel or kerosene considering it comes out of the refinery process first. Therefore it is put through less filters. Most likely this isn't going to prove anything but its worth a shot.
But most likely it wont work. Why? Because simply you are not doing anything to change the system. All you are doing is temporarily stopping magnetic bits (if any) from entering the injectors. As these metal bits build up eventually they will start being swept away by the flow of fuel in the system. If there were a filter of some sort that had to be changed, then that would make it more plausible. However, most of these systems are filter-less, so therefore they are probably useless. Just my thoughts
The Following User Says Thank You to Revv For This Useful Post:
mcrews (06-06-2012)
Old 06-06-2012, 03:06 PM   #233 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
revv, very logical AND impressive!!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Revv (06-06-2012)
Old 06-06-2012, 05:45 PM   #234 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Old Tele man View Post
EV's = "...may the Electro-Magnetic Force (EMF) be with you!"
That was a repulsive pun.
Old 06-06-2012, 07:24 PM   #235 (permalink)
MPGuino Supporter
t vago's Avatar
You seem rather attached, too. Perhaps we ought to ask a moderator to field these posts... Or maybe just pole away from this thread altogether?
Old 06-07-2012, 02:01 AM   #236 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Word from a moderator:
Guys, your magnetism towards each other is getting off topic
Old 06-07-2012, 03:33 AM   #237 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Good grief.
Old 06-07-2012, 03:41 AM   #238 (permalink)
MPGuino Supporter
t vago's Avatar
Hey, I don't really have any attraction toward this topic. However, all these responses make it difficult to pull my attention away from it.
Old 06-07-2012, 05:38 AM   #239 (permalink)
aero guerrilla
Piwoslaw's Avatar
Imagine drafting behind a truck which is carrying a bunch of magnets. That could increase your milage.
Old 06-07-2012, 01:14 PM   #240 (permalink)
I am involved with a couple of projects but I would be interested in helping design some experiments.
Magnetic engine returns BillWhedon The Unicorn Corral 22 03-13-2013 04:09 AM
Uk ford transit, economy increase? chipX EcoModding Central 14 10-11-2012 03:38 AM
Magnets (as attachment method) jmonroe Aerodynamics 10 03-07-2009 02:12 AM
New Report of 20% milage increase by reducing viscosity of fuel htaylor EcoModding Central 29 01-27-2009 01:35 AM
magnets use for permanent mods ? groar EcoModding Central 5 09-08-2008 04:52 PM
