02-27-2016, 12:08 PM
#51 (permalink)
Safety only inspection (air is safety over inflation has a history of explosives rim failure not commen) reg and ins in some places means you meet equipment ie all required is equipped and gas emission levels are exceptable
With this said if you are lucky enough to live in a nonCARB/EPA TESTING regen or your rig is old enough like my 91 diesel
Its a. "OPEN SHOW" run what you brung.
This sounds fun. Hope I can make it this year.
If i do make it could i run 2 times. An A B TEST 1without airo mod in stock class and 2 in mod class with airo modds. Do you think this is possible? I expect that it will cost 2x but thats ok
02-28-2016, 07:09 PM
#52 (permalink)
Changfa diesel + Suzuki
Centurion - '74 FIAT X1/9 Centurion Full Race DNA Last 3: 143.5 mpg (US)
Originally Posted by brucepick
Very true.
The car must be registered for road use, with plates, and insured.
Inspection checks all exterior lights and tire pressure, and may check tire size. They might check wipers; I can't recall. They do allow a few pounds increase in tire pressure from driving up to the event. That is, I had entered as "Modified Production", so the limit was 50 psi. The inspector's gauge showed 52; he said that was fine because when cold the tires would have been several psi less - which is a true statement.
Of course if you enter as Stock Production, you can't show up with aero panels added all over your car. Stickers, decals, and even added instrumentation don't count as modifications, so far as I know.
It's as brucepick has outlined above. My 1st year it seemed like everything was checked pretty good: all four tires (air pressure), handbrake, all lights (tail, turn, brake, headlights) the wiper, & horn. It doesn't take too long really and adds to the overall experience!
~CrazyJerry
02-28-2016, 08:38 PM
#53 (permalink)
OCD Master EcoModder
gumby79, the schedule at the GGP is pretty packed. Any given car can run in up to two events, that's it. However, each event is about two hours of drive time. Take a look at their site (greengrandprix.com), go to the "Schedule" link.
The run on the Watkins Glen track is about two hours of driving time, and the time-speed-distance rally on state and local roads is also about two hours. There's a third equally long event, exclusively for Priuses. Add some time for the formalities of registration, inspection, Drivers' Meeting, and fillups before/after the events. It's a very full day.
Coast long and prosper.
02-28-2016, 09:29 PM
#54 (permalink)
Too many cars
All cars will be on the track at the same time (2-4 PM) this year.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
03-03-2016, 02:53 AM
#55 (permalink)
What other GGP type events are available as to long days behind the wheel. "Racing" is not like hwy driving. Agreed. Just thought it would be a exlant ab test for airo. But all at once eliminated that idea. Good luck to all. Is their a ton mpg comparisons made ro level the playing field ?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
03-05-2016, 09:18 PM
#56 (permalink)
Neutral is my favorite
Will you be running the tank in the Exhibition: class
You. Have a "race only" rig NOT STREET LEGAL as per the EPA /CAEB:
1. No cat in down pipe as per your garage profile NOT CARB approved as wouldNOT pass visual smog inspection.if it cant pass that it is for off-road (race) use only
2. HAI/CAI is it off the shelf CARB # xxxx or as mying will be home made custom as "I" want it. If no sticker Exhibition class required because not street leagal. Can it pass an enhanced smog test(underload on a dino) with the hot air intake active or are the NOXX too high from an over heated communication temp too far above 2500°f
Theas Questions is for all ecomodders ,me inclided
If someone frome the GGP could pipe in that would be kool as well
I'm not trying to single out any one modder.
Thanks in advance
1. I have 2 cats. The factory design was a pre-cat and cat on each side. I bought new cats after the old ones crapped out. Since catalytic converters have become more advanced, the new design only included the cats; no more pre-cats. These were ordered from Walker through Advance Auto. Totally legal (I've had them on the car for 7 years now)
2. I'm reverting back to a factory intake. It's actually from an 04 Police Interceptor. They cam with larger 80mm MAF and larger airboxes from the factory.
No problem bringing this up. I'm sure other folks had similar questions.
I hope you can make it this year!
-ryan s.
1997 Ford Crown Victoria HPP- "Tank of Justice III" 194k - 578.9 miles on ONE tank
2003 Mercury Marauder- 63k, not so fuel efficient; #1,548 of 11,052
2008 Lincoln Navigator L - 244k (don't ask about mpg)
04-06-2016, 08:44 AM
#57 (permalink)
2016 Green Grand Prix press release:
Green Grand Prix features innovation - observer-review.com
9 days 'till event day!!!!!
~CrazyJerry
The Following User Says Thank You to changzuki For This Useful Post:
04-06-2016, 08:30 PM
#58 (permalink)
Oh geez. Time for turbo boost to get this done!!
-ryan s.
04-12-2016, 06:30 PM
#60 (permalink)
Originally Posted by changzuki
Three days until event day!!!
~CrazyJerry
The Final Countdown...
The Following 2 Users Say Thank You to redneck For This Useful Post:
