https://www.washingtonexaminer.com/n...green-new-deal Quote:
She should follow her own advice... ![]() > |
#6872 (permalink) |
Sub - '84 Chevy Diesel Suburban C10 SUV 90 day: 19.5 mpg (US) camaro - '85 Chevy Camaro Z28 Riot - '03 Kia Rio POS Team Hyundai 90 day: 30.21 mpg (US) Bug - '01 VW Beetle GLSturbo 90 day: 26.43 mpg (US) Sub2500 - '86 GMC Suburban C2500 90 day: 11.95 mpg (US) Snow flake - '11 Nissan Leaf SL SUV 90 day: 141.63 mpg (US) Thanks: 273
Miami was supposed to be under water by now if you lived in the 1990s.
1984 chevy suburban, custom made 6.5L diesel turbocharged with a Garrett T76 and Holset HE351VE, 22:1 compression 13psi of intercooled boost. 1989 firebird mostly stock. Aside from the 6-speed manual trans, corvette gen 5 front brakes, 1LE drive shaft, 4th Gen disc brake fbody rear end. 2011 leaf SL, white, portable 240v CHAdeMO, trailer hitch, new batt as of 2014. |
The Following User Says Thank You to oil pan 4 For This Useful Post: | aerohead ![]() |
#6873 (permalink) |
Wouldn't it be a hoot if she is right — but not because the oceans rise but because the land falls?
Port Royal was a hive of scum and villainy just like Miami.
. .Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster ___________________ . .tragectory: Line goes down and to the right. |
The Following User Says Thank You to freebeard For This Useful Post: | oil pan 4 ![]() |
#6874 (permalink) |
The oceans do rise, so?
A colleague of mine just returned from Venice. He says 90% of all buildings are damaged by recent repetitive flooding; centuries old plaster walls now washed away by the rising seas. But no, the land may be sinking. Ha ha stupid climate change believers. The mental gymnastics some go through to avoid the obvious is impressive.
2011 Honda Insight + HID, LEDs, tiny PV panel, extra brake pad return springs, neutral wheel alignment, 44/42 PSI (air), PHEV light (inop), tightened wheel nut. ![]() ![]() ![]() For confirmation go to people just like you. For education go to people unlike yourself. Last edited by RedDevil; 09-16-2019 at 06:07 AM.. |
The Following 2 Users Say Thank You to RedDevil For This Useful Post: |
#6875 (permalink) |
That's what you get for build your city at sea level on top of the sea.
Plus they have been sinking. At least the Netherlands has a wall so there is a chance the seas can be held back for a little while longer, but eventually the inevitable fate will be realized. Yet people still live in these places. Yes, stupid climate change believers indeed. You say all these things and take no action.
#6876 (permalink) |
Honda CBR250R FI Single - '11 Honda CBR250R 90 day: 105.14 mpg (US) 2001 Honda Insight stick - '01 Honda Insight manual 90 day: 60.68 mpg (US) 2009 Honda Fit auto - '09 Honda Fit Auto 90 day: 38.51 mpg (US) PCX153 - '13 Honda PCX150 90 day: 104.48 mpg (US) 2015 Yamaha R3 - '15 Yamaha R3 90 day: 80.94 mpg (US) Ninja650 - '19 Kawasaki Ninja 650 90 day: 72.57 mpg (US) Thanks: 326
It needs to be against code to rebuild these non-resilient places whenever they get destroyed by a storm.
The Following User Says Thank You to sendler For This Useful Post: | aerohead ![]() |
#6877 (permalink) |
Mica Blue - '05 Scion xA RS 2.0 Team Toyota 90 day: 42.48 mpg (US) Forest - '15 Nissan Leaf S Team Nissan 90 day: 156.46 mpg (US) Number 7 - '15 VW e-Golf SEL TEAM VW AUDI Group 90 day: 155.81 mpg (US) Thanks: 3,475
Reference, please.
#6878 (permalink) | |
The results are the same - and they are both based on science and data. |
The Following User Says Thank You to NeilBlanchard For This Useful Post: | aerohead ![]() |
#6879 (permalink) | |
https://www.washingtonexaminer.com/n...green-new-deal She should follow her own advice... > |
#6880 (permalink) |
About living at sea level.
We always lived at sea level. We recently discovered a Roman road nearby (Vianen) deep in the ground, well below our current sea level, but permanently dry in Roman times 21 centuries ago and up until recently. It would still be above sea level if we had not burned fossil fuel over the last 2 centuries. So, must we flee for mindless spillage, or must we fight it? I banned Oil Pan for a reason, but I just viewed his blocked message anyway. It just confirms I did the right thing.
2011 Honda Insight + HID, LEDs, tiny PV panel, extra brake pad return springs, neutral wheel alignment, 44/42 PSI (air), PHEV light (inop), tightened wheel nut. ![]() ![]() ![]() For confirmation go to people just like you. For education go to people unlike yourself. Last edited by RedDevil; 09-17-2019 at 02:49 AM.. |
